Will not open calendar
On attempting to switch to Calendar window, this message appears:-[Window Title]eM Client
[Main Instruction]
eM Client has stopped working
[Content]
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
[Close program]
Checks for, but does not find any corruption.
Version 7.0.27943.0
How do I fix, please?
I get the exact same thing. Cannpt access my calendar anymore. Same version
Me too. Also does the same thing when trying to open Contacts, tasks
could you screenshot the window, please?
Screenshot attempted as requested. I will have to submit my reply to prove screenshot has uploaded. Ken
All I do is click on any method to open the calendar or Contacts and it stops
Here is the error details:
eM Client (7.0.27943.0)
Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.42000
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.NullReferenceException: Object reference not set to an instance of an object.
at System.TimeZoneInfo.FromRegistryKey(String id, RegistryKey key)
at System.TimeZoneInfo.FindSystemTimeZoneById(String id)
at System.TimeZoneInfo.CreateLocal()
at System.TimeZoneInfo.get_Local()
at MailClient.Storage.Application.Schedule.ScheduleItem1..ctor() at MailClient.UI.Controls.ControlSidebar.ControlSidebarBoxToDo.\<\>c\_\_DisplayClass86\_0.b\_\_1() --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Delegate.DynamicInvokeImpl(Object[] args) at MailClient.Common.UI.Marshalling.\<\>c\_\_DisplayClass10\_0.b\_\_0() --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at MailClient.Common.UI.Forms.BaseForm.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at MailClient.Program.\<\>c.b\_\_62\_3() --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at MailClient.Common.UI.Forms.BaseForm.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at Xilium.CefGlue.Interop.libcef.run\_message\_loop() at MailClient.Program.\<\>c.b\_\_62\_2() at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action1 handler)
eM Client
7.0.27943.0
false
4.0.30319.42000
mscorlib
mscorlib.dll
100667731
mscorlib
InvokeMethod
mscorlib
System.Object
target
mscorlib
System.Object[]
arguments
mscorlib
System.Signature
sig
mscorlib
System.Boolean
constructor
ffffffff
0
mscorlib.dll
100680927
mscorlib
mscorlib
System.Object
obj
mscorlib
System.Object[]
parameters
mscorlib
System.Object[]
arguments
7
57
mscorlib.dll
100664795
mscorlib
System.Delegate
DynamicInvokeImpl
mscorlib
System.Object[]
args
24
75
System.Windows.Forms.dll
100666556
System.Windows.Forms.Control+ThreadMethodEntry
tme
cf
ae
100666555
mscorlib
System.Object
obj
20
62
mscorlib.dll
100678072
mscorlib
RunInternal
mscorlib
executionContext
mscorlib
System.Threading.ContextCallback
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
79
c1
mscorlib.dll
100678071
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
0
15
mscorlib.dll
100678070
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
2b
40
100666554
tme
37
94
100666557
58
132
100666850
WndProc
System.Windows.Forms.Message&
m
655
144
100676228
WndProc
m
34
2f
100672137
WndProc
m
26f
69
MailClient.Common.UI.dll
100663775
WndProc
m
36
45
100684797
System.Windows.Forms.Control+ControlNativeWindow
OnMessage
m
0
12
100684800
WndProc
m
8e
34
100674589
DebuggableCallback
mscorlib
System.IntPtr
hWnd
mscorlib
System.Int32
msg
mscorlib
System.IntPtr
wparam
mscorlib
System.IntPtr
lparam
25
5d
Xilium.CefGlue.dll
100666825
Xilium.CefGlue
run_message_loop
ffffffff
0
MailClient.exe
100688544
MailClient
MailClient.Program+<>c
b__62_2
41
bf
MailClient.ExceptionUtils.dll
100663314
Filter
MailClient.ExceptionUtils.ExceptionUtils+BodyDelegate
body
MailClient.ExceptionUtils.ExceptionUtils+FilterDelegate
filter
mscorlib
System.Action`1[[System.Exception, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]
handler
0
22
mscorlib
mscorlib.dll
100667731
mscorlib
InvokeMethod
mscorlib
System.Object
target
mscorlib
System.Object[]
arguments
mscorlib
System.Signature
sig
mscorlib
System.Boolean
constructor
ffffffff
0
mscorlib.dll
100680927
mscorlib
mscorlib
System.Object
obj
mscorlib
System.Object[]
parameters
mscorlib
System.Object[]
arguments
7
57
mscorlib.dll
100664795
mscorlib
System.Delegate
DynamicInvokeImpl
mscorlib
System.Object[]
args
24
75
100666556
tme
cf
ae
100666555
mscorlib
System.Object
obj
20
62
mscorlib.dll
100678072
mscorlib
RunInternal
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
79
c1
mscorlib.dll
100678071
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
0
15
mscorlib.dll
100678070
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
2b
40
100666554
tme
37
94
100666557
58
132
100666850
WndProc
m
655
144
100676228
WndProc
m
34
2f
100672137
WndProc
m
26f
69
100663775
WndProc
m
36
45
100684797
OnMessage
m
0
12
100684800
WndProc
m
8e
34
100674589
DebuggableCallback
mscorlib
System.IntPtr
hWnd
mscorlib
System.Int32
msg
mscorlib
System.IntPtr
wparam
mscorlib
System.IntPtr
lparam
25
5d
100681063
DispatchMessageW
System.Windows.Forms.NativeMethods+MSG&
msg
ffffffff
0
100684364
System.Windows.Forms.Application+ComponentManager
mscorlib
System.IntPtr
dwComponentID
mscorlib
System.Int32
reason
mscorlib
System.Int32
pvLoopData
177
24c
100684410
System.Windows.Forms.Application+ThreadContext
RunMessageLoopInner
mscorlib
System.Int32
reason
System.Windows.Forms.ApplicationContext
context
1df
154
100684409
RunMessageLoop
mscorlib
System.Int32
reason
context
14
4b
MailClient.exe
100688545
MailClient
b__62_3
0
2c
mscorlib
mscorlib.dll
100667731
mscorlib
InvokeMethod
mscorlib
System.Object
target
mscorlib
System.Object[]
arguments
mscorlib
System.Signature
sig
mscorlib
System.Boolean
constructor
ffffffff
0
mscorlib.dll
100680927
mscorlib
mscorlib
System.Object
obj
mscorlib
System.Object[]
parameters
mscorlib
System.Object[]
arguments
7
57
mscorlib.dll
100664795
mscorlib
System.Delegate
DynamicInvokeImpl
mscorlib
System.Object[]
args
24
75
100666867
MailClient.Common.UI.Marshalling+<>c__DisplayClass10_0
b__0
14
36
SystemCoreTimeZone
SystemCoreTimeZone.dll
100663328
SystemCoreTimeZone
System.TimeZoneInfo
FromRegistryKey
mscorlib
System.String
id
mscorlib
Microsoft.Win32.RegistryKey
key
89
150
100663327
SystemCoreTimeZone
System.TimeZoneInfo
mscorlib
System.String
id
62
96
100663337
SystemCoreTimeZone
System.TimeZoneInfo
CreateLocal
54
15d
100663324
SystemCoreTimeZone
System.TimeZoneInfo
get_Local
9
21
MailClient.Accounts.dll
100664093
MailClient.Accounts
MailClient.Storage.Application.Schedule.ScheduleItem`1
.ctor
1d
91
MailClient.exe
100692061
MailClient
MailClient.UI.Controls.ControlSidebar.ControlSidebarBoxToDo+<>c__DisplayClass86_0
b__1
2c
8c
MailClient.exe
C:\Program Files (x86)\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
7.0.27943.0
eM Client
eM Client
7.0.27943.0
False
False
False
False
False
Language Neutral
ntdll.dll
C:\Windows\SysWOW64\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.1.7600.16385 (win7_rtm.090713-1255)
NT Layer DLL
Microsoft® Windows® Operating System
6.1.7600.16385
False
False
False
False
False
English (United States)
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
4.0.40305.0 (Main.040305-0000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
4.0.40305.0
False
False
False
True
False
KERNEL32.dll
C:\Windows\syswow64\KERNEL32.dll
kernel32
kernel32
6.1.7601.17965 (win7sp1_gdr.121004-0333)
Windows NT BASE API Client DLL
6.1.7601.17965
False
False
False
False
False
KERNELBASE.dll
C:\Windows\syswow64\KERNELBASE.dll
Kernelbase
Kernelbase
6.1.7601.17965
False
False
False
False
False
TmUmEvt.dll
C:\Windows\SysWOW64\tmumh\20019\AddOn\6.80.0.1007\TmUmEvt.dll
TmUmEvt.dll
TmUmEvt.dll
6.80.0.1007
Trend Micro User-Mode Hook Event Module
Trend Micro Eyes
6.80
False
False
False
True
True
PSAPI.DLL
C:\Windows\syswow64\PSAPI.DLL
PSAPI
PSAPI
Process Status Helper
6.1.7600.16385
False
False
False
False
False
SHLWAPI.dll
C:\Windows\syswow64\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell Light-weight Utility Library
6.1.7600.16385
False
False
False
False
False
GDI32.dll
C:\Windows\syswow64\GDI32.dll
gdi32
gdi32
6.1.7601.23591 (win7sp1_ldr.161106-0500)
GDI Client DLL
6.1.7601.23591
False
False
False
False
False
USER32.dll
C:\Windows\syswow64\USER32.dll
user32
user32
6.1.7601.17514 (win7sp1_rtm.101119-1850)
Multi-User Windows USER API Client DLL
6.1.7601.17514
False
False
False
False
False
ADVAPI32.dll
C:\Windows\syswow64\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
6.1.7601.23572 (win7sp1_ldr.161011-0600)
Advanced Windows 32 Base API
6.1.7601.23572
False
False
False
False
False
msvcrt.dll
C:\Windows\syswow64\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.7601.17744 (win7sp1_gdr.111215-1535)
Windows NT CRT DLL
7.0.7601.17744
False
False
False
False
False
sechost.dll
C:\Windows\SysWOW64\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
6.1.7600.16385
False
False
False
False
False
RPCRT4.dll
C:\Windows\syswow64\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Remote Procedure Call Runtime
6.1.7600.16385
False
False
False
False
False
SspiCli.dll
C:\Windows\syswow64\SspiCli.dll
security.dll
security.dll
6.1.7601.23642 (win7sp1_ldr.170105-0730)
Security Support Provider Interface
6.1.7601.23642
False
False
False
False
False
CRYPTBASE.dll
C:\Windows\syswow64\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
6.1.7601.23642
False
False
False
False
False
LPK.dll
C:\Windows\syswow64\LPK.dll
LanguagePack
LanguagePack
6.1.7601.23587 (win7sp1_ldr.161102-0600)
Language Pack
6.1.7601.23587
False
False
False
False
False
USP10.dll
C:\Windows\syswow64\USP10.dll
Uniscribe
Uniscribe
1.0626.7601.23585 (win7sp1_ldr.161027-0600)
Uniscribe Unicode script processor
Microsoft® Uniscribe Unicode script processor
1.0626.7601.23585
False
False
False
False
False
tmmon.dll
C:\Windows\SysWOW64\tmumh\20019\TmMon\1.6.0.1175\tmmon.dll
1.6.0.1175
Trend Micro UMH Monitor Engine
Trend Micro User Mode Hooking
1.6
False
False
False
False
False
sfc.dll
C:\Windows\system32\sfc.dll
sfc.dll
sfc.dll
Windows File Protection
6.1.7600.16385
False
False
False
False
False
sfc_os.DLL
C:\Windows\system32\sfc_os.DLL
sfc_os.dll
sfc_os.dll
6.1.7600.16385
False
False
False
False
False
VERSION.dll
C:\Windows\system32\VERSION.dll
version
VERSION.DLL
Version Checking and File Installation Libraries
6.1.7600.16385
False
False
False
False
False
IMM32.DLL
C:\Windows\system32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
6.1.7601.17514
False
False
False
False
False
MSCTF.dll
C:\Windows\syswow64\MSCTF.dll
MSCTF
MSCTF.DLL.MUI
MSCTF Server DLL
6.1.7600.16385
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.6.1590.0 built by: NETFXREL2
4.6.1590.0
False
False
False
True
False
clr.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
clr.dll
clr.dll
Microsoft .NET Runtime Common Language Runtime - WorkStation
4.6.1590.0
False
False
False
True
False
MSVCR120_CLR0400.dll
C:\Windows\system32\MSVCR120_CLR0400.dll
msvcr120_clr0400.dll
12.00.52512.0 built by: VSWINSERVICING
Microsoft® C Runtime Library
Microsoft® Visual Studio® 2013
12.00.52512.0
False
False
False
False
False
mscorlib.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\7582400666d289c016013ad0f6e0e3e6\mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
Microsoft Common Language Runtime Class Library
4.6.1590.0
False
False
False
True
False
ole32.dll
C:\Windows\syswow64\ole32.dll
OLE32.DLL
OLE32.DLL.MUI
Microsoft OLE for Windows
6.1.7600.16385
False
False
False
False
False
tiptsf.dll
C:\Program Files (x86)\Common Files\microsoft shared\ink\tiptsf.dll
TipTsf.dll
TipTsf.dll.mui
Tablet PC Input Panel Text Services Framework
6.1.7600.16385
False
False
False
False
False
OLEAUT32.dll
C:\Windows\syswow64\OLEAUT32.dll
OLEAUT32.DLL
6.1.7601.23569
6.1.7601.23569
False
False
False
False
False
CRYPTSP.dll
C:\Windows\system32\CRYPTSP.dll
cryptsp.dll
cryptsp.dll
6.1.7601.23471 (win7sp1_ldr.160614-0600)
Cryptographic Service Provider API
6.1.7601.23471
False
False
False
False
False
rsaenh.dll
C:\Windows\system32\rsaenh.dll
rsaenh.dll
rsaenh.dll
Microsoft Enhanced Cryptographic Provider
6.1.7600.16385
False
False
False
False
False
System.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System\1be7a15b1f33bf22e4f53aaf45518c77\System.ni.dll
System.dll
System.dll
.NET Framework
4.6.1590.0
False
False
False
True
False
MailClient.Mail.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Mail\ac43c76c7517d899c6ed4f8c047aa86c\MailClient.Mail.ni.dll
MailClient.Mail.dll
MailClient.Mail.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
HTMLEditorControl.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\HTMLEditorControl\9d3c59e552dd6d7f08d7f3d5bc9a9cf0\HTMLEditorControl.ni.dll
HTMLEditorControl.dll
7.0.27943.0
HtmlEditorControl
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Collections.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.1d52ed9e#\1e790f07f805618c6a2de8ea20baf85b\MailClient.Collections.ni.dll
MailClient.Collections.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.ni.exe
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient\d19679e0666d2699457fe6850257cc24\MailClient.ni.exe
MailClient.exe
MailClient.exe
7.0.27943.0
eM Client
eM Client
7.0.27943.0
False
False
False
False
False
Language Neutral
LinqBridge.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\LinqBridge\52cf6dcddf1770e82a6e2e05b40764c9\LinqBridge.ni.dll
LinqBridge.dll
LinqBridge.dll
1.3.13216.2214
LINQBridge
LINQBridge
1.3.13216.2214
False
False
False
False
False
Language Neutral
MailClient.Accounts.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Accounts\3cc588d02170065ac058296e3c5e71c8\MailClient.Accounts.ni.dll
7.0.27943.0
MailClient.Accounts
MailClient.Accounts
7.0.27943.0
False
False
False
False
False
Language Neutral
System.Drawing.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\1d52bd4ac5e0a6422058a5d62c9f6d9d\System.Drawing.ni.dll
System.Drawing.dll
System.Drawing.dll
.NET Framework
4.6.1590.0
False
False
False
True
False
System.Windows.Forms.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\fb06ad4bc55b9c3ca68a3f9259d826cd\System.Windows.Forms.ni.dll
.NET Framework
4.6.1590.0
False
False
False
True
False
MailClient.Storage.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Storage\55932922c40e0bc8aef078d1f1ab7ac6\MailClient.Storage.ni.dll
MailClient.Storage.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Common.UI.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Common.UI\a1ae5a1bded1f32dc5d4dbb900c73bf6\MailClient.Common.UI.ni.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Interop.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Interop\44cb726ad73c30a878e83365885eb935\MailClient.Interop.ni.dll
MailClient.Interop.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.ExceptionUtils.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.ad6c0f7b#\05d0eeb1792812d944cf085c8aa4755e\MailClient.ExceptionUtils.ni.dll
1.0.0.0
1.0.0.0
False
False
False
False
False
Language Neutral
jabber-net.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\jabber-net\27eb1321763c12a199d159021f7757fc\jabber-net.ni.dll
jabber-net.dll
jabber-net.dll
7.0.0.3
Jabber-Net library
jabber-net
7.0.0.3
False
False
False
False
False
Language Neutral
MailClient.Protocols.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Protocols\9aa6c05f6ee1cf9137fede069416085e\MailClient.Protocols.ni.dll
MailClient.Protocols.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
Xilium.CefGlue.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\Xilium.CefGlue\550ac1298b0f15df1501f5bc90951913\Xilium.CefGlue.ni.dll
Xilium.CefGlue.dll
Xilium.CefGlue.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
Microsoft.Experimental.IO.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\Microsoft.E765800fb#\628a6fc4d08eb963f357e6589322373f\Microsoft.Experimental.IO.ni.dll
Microsoft.Experimental.IO.dll
1.0.0.3
1.0.0.3
False
False
False
False
False
Language Neutral
WinApi.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\WinApi\4b387a2139c1a8eb14f57f5ae4a21886\WinApi.ni.dll
WinApi.dll
WinApi.dll
1.1.27943.0
WinApi
WinApi
1.1.27943.0
False
False
False
False
False
Language Neutral
System.Core.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Core\eb4cca4f06a15158c3f7e2c56516729b\System.Core.ni.dll
System.Core.dll
System.Core.dll
.NET Framework
4.6.1590.0
False
False
False
True
False
System.Data.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Data\6e322d1b2e3358fa90494bffbe32cbf2\System.Data.ni.dll
system.data.dll
system.data.dll
.NET Framework
4.6.1590.0
False
False
False
True
False
System.Data.dll
C:\Windows\Microsoft.Net\assembly\GAC_32\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll
system.data.dll
system.data.dll
.NET Framework
4.6.1590.0
False
False
False
True
False
WS2_32.dll
C:\Windows\syswow64\WS2_32.dll
ws2_32.dll
ws2_32.dll.mui
Windows Socket 2.0 32-Bit DLL
6.1.7600.16385
False
False
False
False
False
NSI.dll
C:\Windows\syswow64\NSI.dll
nsi.dll
nsi.dll
NSI User-mode interface DLL
6.1.7600.16385
False
False
False
False
False
CRYPT32.dll
C:\Windows\syswow64\CRYPT32.dll
CRYPT32.DLL
CRYPT32.DLL.MUI
6.1.7601.23566 (win7sp1_ldr.161004-0600)
Crypto API32
6.1.7601.23566
False
False
False
False
False
MSASN1.dll
C:\Windows\syswow64\MSASN1.dll
msasn1.dll
msasn1.dll
ASN.1 Runtime APIs
6.1.7601.17514
False
False
False
False
False
libcef.DLL
C:\Program Files (x86)\eM Client\libcef.DLL
libcef
libcef.dll
3.2623.1422.gcb2184a
Chromium Embedded Framework (CEF) Dynamic Link Library
False
False
False
False
False
WINSPOOL.DRV
C:\Windows\system32\WINSPOOL.DRV
winspool.drv
winspool.drv.mui
Windows Spooler Driver
6.1.7600.16385
False
False
False
False
False
COMDLG32.dll
C:\Windows\syswow64\COMDLG32.dll
comdlg32
comdlg32.dll.mui
Common Dialogs DLL
6.1.7600.16385
False
False
False
False
False
COMCTL32.dll
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_41e855142bd5705d\COMCTL32.dll
comctl32
comctl32.DLL.MUI
6.10 (win7_rtm.090713-1255)
User Experience Controls Library
6.1.7600.16385
False
False
False
False
False
SHELL32.dll
C:\Windows\syswow64\SHELL32.dll
SHELL32
SHELL32.DLL.MUI
Windows Shell Common Dll
6.1.7601.17514
False
False
False
False
False
WINHTTP.dll
C:\Windows\system32\WINHTTP.dll
winhttp.dll
winhttp.dll.mui
Windows HTTP Services
6.1.7600.16385
False
False
False
False
False
webio.dll
C:\Windows\system32\webio.dll
webio.dll
webio.dll.mui
Web Transfer Protocols API
6.1.7601.17514
False
False
False
False
False
USERENV.dll
C:\Windows\syswow64\USERENV.dll
userenv
userenv.dll.mui
Userenv
6.1.7600.16385
False
False
False
False
False
profapi.dll
C:\Windows\syswow64\profapi.dll
PROFAPI.DLL
PROFAPI.DLL
User Profile Basic API
6.1.7600.16385
False
False
False
False
False
urlmon.dll
C:\Windows\syswow64\urlmon.dll
UrlMon.dll
UrlMon.dll.mui
11.00.9600.18538 (winblue_ltsb.161112-0600)
OLE32 Extensions for Win32
Internet Explorer
11.00.9600.18538
False
False
False
False
False
api-ms-win-downlevel-ole32-l1-1-0.dll
C:\Windows\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll
apisetstub
apisetstub
6.2.9200.16492 (win8_gdr_oobssr.130113-0015)
ApiSet Stub DLL
6.2.9200.16492
False
False
False
False
False
api-ms-win-downlevel-shlwapi-l1-1-0.dll
C:\Windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
apisetstub
apisetstub
ApiSet Stub DLL
6.2.9200.16492
False
False
False
False
False
api-ms-win-downlevel-advapi32-l1-1-0.dll
C:\Windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
apisetstub
apisetstub
ApiSet Stub DLL
6.2.9200.16492
False
False
False
False
False
api-ms-win-downlevel-user32-l1-1-0.dll
C:\Windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll
apisetstub
apisetstub
ApiSet Stub DLL
6.2.9200.16492
False
False
False
False
False
api-ms-win-downlevel-version-l1-1-0.dll
C:\Windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll
apisetstub
apisetstub
ApiSet Stub DLL
6.2.9200.16492
False
False
False
False
False
api-ms-win-downlevel-normaliz-l1-1-0.dll
C:\Windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
apisetstub
apisetstub
ApiSet Stub DLL
6.2.9200.16492
False
False
False
False
False
normaliz.DLL
C:\Windows\syswow64\normaliz.DLL
normaliz
normaliz.dll
Unicode Normalization DLL
6.1.7600.16385
False
False
False
False
False
iertutil.dll
C:\Windows\syswow64\iertutil.dll
IeRtUtil.dll
IeRtUtil.dll
Run time utility for Internet Explorer
Internet Explorer
11.00.9600.18538
False
False
False
False
False
WININET.dll
C:\Windows\syswow64\WININET.dll
wininet.dll
wininet.dll.mui
Internet Extensions for Win32
Internet Explorer
11.00.9600.18538
False
False
False
False
False
dhcpcsvc.DLL
C:\Windows\system32\dhcpcsvc.DLL
dhcpcsvc.dll
dhcpcsvc.dll.mui
DHCP Client Service
6.1.7600.16385
False
False
False
False
False
WTSAPI32.dll
C:\Windows\system32\WTSAPI32.dll
wtsapi32.dll
wtsapi32.dll
Windows Remote Desktop Session Host Server SDK APIs
6.1.7601.17514
False
False
False
