I can adjust the column widths easily enough, but not the width of the slider bar on the right side of the window. It is very narrow and I am having great difficulty getting/clicking my mouse pointer onto the slider so that I can move swiftly up and down my messages.
Is there a way to make it wider please?
jueves 13 enero 2022 :: 1206hrs (UTC +01:00)
Hi @BobFletcher
You can use the Theme Editor to change width of Scroll Bars:
Either: Menu ->Appearance ->Themes ->Theme Editor
Or: Menu ->Tools ->Theme Editor
And: If you are really stuck ask and I will do it for you.
¡Saludos desde la soleada Sevilla España!
Skybat
[email protected]
You can download the default Modern Theme with wider scrollbars : https://www.emclient.com/api/themes/28/download
Lots of cool eM Client User themes from url - Themes | Custom Themes from Our Users | eM Client
Thank you very much. I am getting a bit old and find some technical things a bit difficult,
but this worked perfectly.
Bob
PS. I wish I could speak Spanish (or Portuguese) as well as you speak English.
Thanks for reply - SkyBat solution worked for me
Bob
Thanks for reply - SkyBat solution worked for me.
Bob
