Hi I’m using em client over two user accounts on one pc, on the second account the widgets are missing how can I solve this? The install for em client is in the same location being “program files” on both accounts.
you can show widgets if you right-click on the caption of any box on the left side (Mail, Calendar, Tasks or Contacts) - then select widgets from the context menu which appears
