The Widget display won’t format properly or allow you to modify the size of a widget. When I add a widget, it is added in an extremely narrow column, so only a small portion of it is visible. Screenshot below. Dragging it to make it larger does not work. Deleting all columns and starting over doesn’t work. Refreshing doesn’t work.
Would really like to be able to add my widgets back, as being able to use them with eM Client is a big part of its appeal for me. Please advise. Thanks.
