When running a rule eM Client won't keep selected folder
When running a rule, the selected folder does not populate, then when I run the rule it says no folder selected. Any suggestions?
I think the problem is that you need to, when selecting folder/s, check the checkbox near to folder name and confirm that. Selected folder/s will be displayed then as a list near the Folder: caption and you can run a rule now. Hope this solves your problem.
Regards
