Thank you for providing a free version of this great software!
I have a suggested tweak: when one manually runs a rule, it would be great if EM Client automatically selected the currently open folder as the default location to run the rule (Rules | Apply Rule | Select folder(s)).
For example, if the “Inbox” is open, the rule would automatically select the inbox (a user could still change that, or add more folders).
If you right-click on the folder you want to use and choose Apply Rule, it will select that folder in the Rule dialogue.
Thanks for the tip!!
