when i try to forward a 7.5 mail it becomes 10.5 and well not go
When i try to forward a video it becomes much bigger and won’t go
Really depends on what your email provider allows. As a general rule, 10MB is the safest size to send.
Go to Menu > Tools > Operations and look in the Log tab for any errors.
Why do they get bigger when i forward them, Tried one today that i got and it was 14 mb and when i tried to forward it  It became 24 mb. went to my gmail and it forwarded it just fine.
I am not seeing that. I attached a number of video files, and the pre-send attachment size is the same as the sent and received size.
What version of eM Client are you using Donewell?
7.2.36465.0
Thought that might be the case; that version was riddled with issues. Go to the Release History and download the latest version. See if there is any difference.
Okay!! Thanks that worked
