This is new, it suddenly started a couple of days ago. I have switched my computer off and on, tried to repair eM Client, uninstalled and reinstalled eM Client.
eM Client (7.0.26687.0)
Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.42000
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Data.SQLite.SQLiteException: SQL logic error or missing database
no such table: contact_data.ContactItemContents
at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
at System.Data.SQLite.SQLiteCommand.BuildNextCommand()
at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteScalar()
at MailClient.Storage.Contact.Data.DbContactRepository.LoadProperty(UInt64 itemId, String propertyName, String propertyId)
at MailClient.Storage.Contact.Data.DbContactRepositoryItem.get_Card()
at MailClient.Storage.Contact.Data.ContactRepositoryItem.Copy()
at MailClient.Storage.Application.Item2.BeginUpdate() at MailClient.UI.Forms.formSendMail.updateRecipientsHistory() at MailClient.UI.Forms.formSendMail.\<\>c\_\_DisplayClass133\_0.<send>b__1()<br> --- End of inner exception stack trace ---<br> at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)<br> at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)<br> at System.Delegate.DynamicInvokeImpl(Object[] args)<br> at MailClient.Common.UI.Marshalling.SafeBeginInvoke(Control control, Delegate method, Object[] parameters)<br> at MailClient.UI.Forms.formSendMail.<>c__DisplayClass133_1.<send>b__0(String innerHtml)<br> at MailClient.Common.UI.Controls.CefWebBrowserEx.CefWebBrowserEx.<>c__DisplayClass158_0.<getcleanedinnerhtml>b__0(CefProcessMessage message)<br> at MailClient.Common.UI.Controls.CefWebBrowserEx.CefWebBrowserEx.OnMessageReceived(CefProcessMessage message)<br> at MailClient.Common.UI.Controls.CefWebBrowserEx.CefWebClientEx.OnProcessMessageReceived(CefBrowser browser, CefProcessId sourceProcess, CefProcessMessage message)<br> at Xilium.CefGlue.CefClient.on_process_message_received(cef_client_t* self, cef_browser_t* browser, CefProcessId source_process, cef_process_message_t* message)<br> at Xilium.CefGlue.Interop.libcef.do_message_loop_work()<br> at MailClient.Program.Application_Idle(Object sender, EventArgs e)<br> at System.Windows.Forms.Application.ThreadContext.System.Windows.Forms.UnsafeNativeMethods.IMsoComponent.FDoIdle(Int32 grfidlef)<br> at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)<br> at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)<br> at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)<br> at MailClient.Program.<>c.<main>b__62_1()<br> at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action
1 handler)
" rel=“nofollow”>http://emclient.com/ns/report ">; eM Client 7.0.26687.0 false Microsoft Windows NT 6.1.7601 Service Pack 1 4.0.30319.42000 System.Reflection.TargetInvocationException Exception has been thrown by the target of an invocation. mscorlib
mscorlib.dll 100667723 mscorlib System.RuntimeMethodHandle InvokeMethod mscorlib System.Object target mscorlib System.Object[] arguments mscorlib System.Signature sig mscorlib System.Boolean constructor ffffffff 0
mscorlib.dll 100680823 mscorlib System.Reflection.RuntimeMethodInfo UnsafeInvokeInternal mscorlib System.Object obj mscorlib System.Object[] parameters mscorlib System.Object[] arguments 7 c0
mscorlib.dll 100664788 mscorlib System.Delegate DynamicInvokeImpl mscorlib System.Object[] args d 75
MailClient.Common.UI.dll 100663409 MailClient.Common.UI MailClient.Common.UI.Marshalling SafeBeginInvoke System.Windows.Forms System.Windows.Forms.Control control mscorlib System.Delegate method mscorlib System.Object[] parameters 6c da
MailClient.exe 100690395 MailClient MailClient.UI.Forms.formSendMail+<>c DisplayClass133_1 <Send>b 0 mscorlib System.String innerHtml 26 5c
MailClient.Common.UI.dll 100667010 MailClient.Common.UI MailClient.Common.UI.Controls.CefWebBrowserEx.CefWebBrowserEx+<>c DisplayClass158_0 <GetCleanedInnerHtml>b 0 Xilium.CefGlue Xilium.CefGlue.CefProcessMessage message 0 83
MailClient.Common.UI.dll 100666334 MailClient.Common.UI MailClient.Common.UI.Controls.CefWebBrowserEx.CefWebBrowserEx OnMessageReceived Xilium.CefGlue Xilium.CefGlue.CefProcessMessage message 76 12f
MailClient.Common.UI.dll 100666343 MailClient.Common.UI MailClient.Common.UI.Controls.CefWebBrowserEx.CefWebClientEx OnProcessMessageReceived Xilium.CefGlue Xilium.CefGlue.CefBrowser browser Xilium.CefGlue Xilium.CefGlue.CefProcessId sourceProcess Xilium.CefGlue Xilium.CefGlue.CefProcessMessage message 0 12
Xilium.CefGlue.dll 100663574 Xilium.CefGlue Xilium.CefGlue.CefClient on_process_message_received Xilium.CefGlue Xilium.CefGlue.Interop.cef_client_t* self Xilium.CefGlue Xilium.CefGlue.Interop.cef_browser_t* browser Xilium.CefGlue Xilium.CefGlue.CefProcessId source_process Xilium.CefGlue Xilium.CefGlue.Interop.cef_process_message_t* message f 40
Xilium.CefGlue.dll 100666812 Xilium.CefGlue Xilium.CefGlue.Interop.libcef do_message_loop_work ffffffff 0
MailClient.exe 100665284 MailClient MailClient.Program Application_Idle mscorlib System.Object sender mscorlib System.EventArgs e 7 32
System.Windows.Forms.dll 100684401 System.Windows.Forms System.Windows.Forms.Application+ThreadContext System.Windows.Forms.UnsafeNativeMethods.IMsoComponent.FDoIdle mscorlib System.Int32 grfidlef 8 42
System.Windows.Forms.dll 100684342 System.Windows.Forms System.Windows.Forms.Application+ComponentManager System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop mscorlib System.IntPtr dwComponentID mscorlib System.Int32 reason mscorlib System.Int32 pvLoopData 1cb 3e2
System.Windows.Forms.dll 100684388 System.Windows.Forms System.Windows.Forms.Application+ThreadContext RunMessageLoopInner mscorlib System.Int32 reason System.Windows.Forms System.Windows.Forms.ApplicationContext context 1df 154
System.Windows.Forms.dll 100684387 System.Windows.Forms System.Windows.Forms.Application+ThreadContext RunMessageLoop mscorlib System.Int32 reason System.Windows.Forms System.Windows.Forms.ApplicationContext context 14 4b
MailClient.exe 100688453 MailClient MailClient.Program+<>c <Main>b__62_1 17 54
MailClient.ExceptionUtils.dll 100663314 MailClient.ExceptionUtils MailClient.ExceptionUtils.ExceptionUtils Filter MailClient.ExceptionUtils MailClient.ExceptionUtils.ExceptionUtils+BodyDelegate body MailClient.ExceptionUtils MailClient.ExceptionUtils.ExceptionUtils+FilterDelegate filter mscorlib System.Action1[[System.Exception, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]</type><br> <name>handler</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>22</nativeoffset><br> <br> </stack><br> <data></data><br> <inner><br> <exception><br> <type>System.Data.SQLite.SQLiteException</type><br> <message>SQL logic error or missing database<br>no such table: contact_data.ContactItemContents</message><br> <source>System.Data.SQLite</source><br> <stack><br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663460</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Prepare</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteConnection</type><br> <name>cnn</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String</type><br> <name>strSql</name><br> </parameter><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>previous</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.UInt32</type><br> <name>timeoutMS</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String&</type><br> <name>strRemain</name><br> </parameter><br> </parameters><br> </method><br> <offset>259</offset><br> <nativeoffset>4c4</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663706</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>BuildNextCommand</name><br> <parameters></parameters><br> </method><br> <offset>f6</offset><br> <nativeoffset>187</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663707</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>GetStatement</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>index</name><br> </parameter><br> </parameters><br> </method><br> <offset>8</offset><br> <nativeoffset>12</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663981</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>NextResult</name><br> <parameters></parameters><br> </method><br> <offset>e4</offset><br> <nativeoffset>112</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663942</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>.ctor</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>cmd</name><br> </parameter><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behave</name><br> </parameter><br> </parameters><br> </method><br> <offset>5d</offset><br> <nativeoffset>72</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663729</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteReader</name><br> <parameters><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behavior</name><br> </parameter><br> </parameters><br> </method><br> <offset>3a</offset><br> <nativeoffset>88</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663733</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteScalar</name><br> <parameters></parameters><br> </method><br> <offset>46</offset><br> <nativeoffset>c2</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Storage.Contact.dll</modulename><br> <metadatatoken>100663440</metadatatoken><br> <assembly>MailClient.Storage.Contact</assembly><br> <type>MailClient.Storage.Contact.Data.DbContactRepository</type><br> <name>LoadProperty</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.UInt64</type><br> <name>itemId</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String</type><br> <name>propertyName</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String</type><br> <name>propertyId</name><br> </parameter><br> </parameters><br> </method><br> <offset>57</offset><br> <nativeoffset>bb</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Storage.Contact.dll</modulename><br> <metadatatoken>100663472</metadatatoken><br> <assembly>MailClient.Storage.Contact</assembly><br> <type>MailClient.Storage.Contact.Data.DbContactRepositoryItem</type><br> <name>get_Card</name><br> <parameters></parameters><br> </method><br> <offset>70</offset><br> <nativeoffset>93</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Storage.Contact.dll</modulename><br> <metadatatoken>100663434</metadatatoken><br> <assembly>MailClient.Storage.Contact</assembly><br> <type>MailClient.Storage.Contact.Data.ContactRepositoryItem</type><br> <name>Copy</name><br> <parameters></parameters><br> </method><br> <offset>4a</offset><br> <nativeoffset>10f</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663839</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Application.Item
2 BeginUpdate 2c 83
MailClient.exe 100672631 MailClient MailClient.UI.Forms.formSendMail updateRecipientsHistory aa 1f8
MailClient.exe 100690393 MailClient MailClient.UI.Forms.formSendMail+<>c DisplayClass133_0 <Send>b 1 46d 76a SELECT “properties” FROM contact_data.ContactItemContents WHERE id=@id and propertyName = @propertyName AND propertyId = @propertyId MailClient.exe C:\Program Files (x86)\eM Client\MailClient.exe MailClient.exe MailClient.exe 7.0.26687.0 eM Client eM Client 7.0.26687.0 False False False False False Language Neutral ntdll.dll C:\windows\SysWOW64\ntdll.dll ntdll.dll ntdll.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) NT Layer DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) MSCOREE.DLL C:\windows\SYSTEM32\MSCOREE.DLL mscoree.dll mscoree.dll 4.0.40305.0 (Main.040305-0000) Microsoft .NET Runtime Execution Engine Microsoft® .NET Framework 4.0.40305.0 False False False True False English (United States) KERNEL32.dll C:\windows\syswow64\KERNEL32.dll kernel32 kernel32 6.1.7601.18015 (win7sp1_gdr.121129-1432) Windows NT BASE API Client DLL Microsoft® Windows® Operating System 6.1.7601.18015 False False False False False English (United States) KERNELBASE.dll C:\windows\syswow64\KERNELBASE.dll Kernelbase Kernelbase 6.1.7601.18015 (win7sp1_gdr.121129-1432) Windows NT BASE API Client DLL Microsoft® Windows® Operating System 6.1.7601.18015 False False False False False English (United States) ADVAPI32.dll C:\windows\syswow64\ADVAPI32.dll advapi32.dll advapi32.dll.mui 6.1.7601.23418 (win7sp1_ldr.160408-2045) Advanced Windows 32 Base API Microsoft® Windows® Operating System 6.1.7601.23418 False False False False False English (United States) msvcrt.dll C:\windows\syswow64\msvcrt.dll msvcrt.dll msvcrt.dll 7.0.7601.17744 (win7sp1_gdr.111215-1535) Windows NT CRT DLL Microsoft® Windows® Operating System 7.0.7601.17744 False False False False False English (United States) sechost.dll C:\windows\SysWOW64\sechost.dll sechost.dll sechost.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Host for SCM/SDDL/LSA Lookup APIs Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) RPCRT4.dll C:\windows\syswow64\RPCRT4.dll rpcrt4.dll rpcrt4.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Remote Procedure Call Runtime Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) SspiCli.dll C:\windows\syswow64\SspiCli.dll security.dll security.dll 6.1.7601.23497 (win7sp1_ldr.160708-0600) Security Support Provider Interface Microsoft® Windows® Operating System 6.1.7601.23497 False False False False False English (United States) CRYPTBASE.dll C:\windows\syswow64\CRYPTBASE.dll cryptbase.dll cryptbase.dll 6.1.7601.23497 (win7sp1_ldr.160708-0600) Base cryptographic API DLL Microsoft® Windows® Operating System 6.1.7601.23497 False False False False False English (United States) mscoreei.dll C:\Windows\Microsoft.NET \Framework\v4.0.30319\mscoreei.dll mscoreei.dll mscoreei.dll 4.6.1076.0 built by: NETFXREL3STAGE Microsoft .NET Runtime Execution Engine Microsoft® .NET Framework 4.6.1076.0 False False False True False English (United States) SHLWAPI.dll C:\windows\syswow64\SHLWAPI.dll SHLWAPI SHLWAPI.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) Shell Light-weight Utility Library Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) GDI32.dll C:\windows\syswow64\GDI32.dll gdi32 gdi32 6.1.7601.23457 (win7sp1_ldr.160518-0600) GDI Client DLL Microsoft® Windows® Operating System 6.1.7601.23457 False False False False False English (United States) USER32.dll C:\windows\syswow64\USER32.dll user32 user32 6.1.7601.17514 (win7sp1_rtm.101119-1850) Multi-User Windows USER API Client DLL Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) LPK.dll C:\windows\syswow64\LPK.dll LanguagePack LanguagePack 6.1.7601.23453 (win7sp1_ldr.160513-1233) Language Pack Microsoft® Windows® Operating System 6.1.7601.23453 False False False False False English (United States) USP10.dll C:\windows\syswow64\USP10.dll Uniscribe Uniscribe 1.0626.7601.19054 (win7sp1_gdr.151103-0600) Uniscribe Unicode script processor Microsoft® Uniscribe Unicode script processor 1.0626.7601.19054 False False False False False English (United States) IMM32.DLL C:\windows\system32\IMM32.DLL imm32 imm32 6.1.7601.17514 (win7sp1_rtm.101119-1850) Multi-User Windows IMM32 API Client DLL Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) MSCTF.dll C:\windows\syswow64\MSCTF.dll MSCTF MSCTF.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) MSCTF Server DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) VERSION.dll C:\windows\system32\VERSION.dll version VERSION.DLL 6.1.7600.16385 (win7_rtm.090713-1255) Version Checking and File Installation Libraries Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) clr.dll C:\Windows\Microsoft.NET \Framework\v4.0.30319\clr.dll clr.dll clr.dll 4.6.1076.0 built by: NETFXREL3STAGE Microsoft .NET Runtime Common Language Runtime - WorkStation Microsoft® .NET Framework 4.6.1076.0 False False False True False English (United States) MSVCR120_CLR0400.dll C:\windows\system32\MSVCR120_CLR0400.dll msvcr120_clr0400.dll msvcr120_clr0400.dll 12.00.52512.0 built by: VSWINSERVICING Microsoft® C Runtime Library Microsoft® Visual Studio® 2013 12.00.52512.0 False False False False False English (United States) mscorlib.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\mscorlib\affcb83bba04f782c2586a1788330891\mscorlib.ni.dll mscorlib.dll mscorlib.dll 4.6.1076.0 built by: NETFXREL3STAGE Microsoft Common Language Runtime Class Library Microsoft® .NET Framework 4.6.1076.0 False False False True False English (United States) ole32.dll C:\windows\syswow64\ole32.dll OLE32.DLL OLE32.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft OLE for Windows Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) uxtheme.dll C:\windows\system32\uxtheme.dll UxTheme.dll UxTheme.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft UxTheme Library Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) CRYPTSP.dll C:\windows\system32\CRYPTSP.dll cryptsp.dll cryptsp.dll 6.1.7601.18741 (win7sp1_gdr.150202-1526) Cryptographic Service Provider API Microsoft® Windows® Operating System 6.1.7601.18741 False False False False False English (United States) rsaenh.dll C:\windows\system32\rsaenh.dll rsaenh.dll rsaenh.dll 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Enhanced Cryptographic Provider Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) System.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System\d03eb8a47500f40d5428f9c6875f8e56\System.ni.dll System.dll System.dll 4.6.1075.0 built by: NETFXREL3STAGE .NET Framework Microsoft® .NET Framework 4.6.1075.0 False False False True False English (United States) MailClient.Mail.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Mail\0ba0cbf58a7fa13d24208d1b5992614f\MailClient.Mail.ni.dll MailClient.Mail.dll MailClient.Mail.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral HTMLEditorControl.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\HTMLEditorControl\ffa912790252fa2ea88e2e8c0b408f23\HTMLEditorControl.ni.dll HTMLEditorControl.dll HTMLEditorControl.dll 7.0.26687.0 HtmlEditorControl 7.0.26687.0 False False False False False Language Neutral MailClient.Collections.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.1d52ed9e#\069fe8f341bb2e0a7fe623a1b50fe137\MailClient.Collections.ni.dll MailClient.Collections.dll MailClient.Collections.dll 7.0.26687.0 MailClient.Collections MailClient.Collections 7.0.26687.0 False False False False False Language Neutral MailClient.ni.exe C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient\5b16263ec6927d897e0a6521f3746c79\MailClient.ni.exe MailClient.exe MailClient.exe 7.0.26687.0 eM Client eM Client 7.0.26687.0 False False False False False Language Neutral LinqBridge.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\LinqBridge\27c3e65aeb6c75cd57e9960fd7bd19d7\LinqBridge.ni.dll LinqBridge.dll LinqBridge.dll 1.3.13216.2214 LINQBridge LINQBridge 1.3.13216.2214 False False False False False Language Neutral MailClient.Accounts.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Accounts\0c86b39935186cb9b752abe4c2e087c2\MailClient.Accounts.ni.dll MailClient.Accounts.dll MailClient.Accounts.dll 7.0.26687.0 MailClient.Accounts MailClient.Accounts 7.0.26687.0 False False False False False Language Neutral System.Drawing.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\48453ce4573683172752f7fdc00f8820\System.Drawing.ni.dll System.Drawing.dll System.Drawing.dll 4.6.1068.2 built by: NETFXREL3STAGE .NET Framework Microsoft® .NET Framework 4.6.1068.2 False False False True False English (United States) System.Windows.Forms.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\7b437291b260f008653ebc86553ab462\System.Windows.Forms.ni.dll System.Windows.Forms.dll System.Windows.Forms.dll 4.6.1055.0 built by: NETFXREL2 .NET Framework Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) MailClient.Storage.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Storage\080e3e8e7910eaaf3545b7fd812e3b12\MailClient.Storage.ni.dll MailClient.Storage.dll MailClient.Storage.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral MailClient.Common.UI.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Common.UI\612c16fa86d5c7f139c5983f941df958\MailClient.Common.UI.ni.dll MailClient.Common.UI.dll MailClient.Common.UI.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral MailClient.Interop.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Interop\13ead7e1ae69eb36d79b4c1ffae6e58c\MailClient.Interop.ni.dll MailClient.Interop.dll MailClient.Interop.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral MailClient.ExceptionUtils.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.ad6c0f7b#\1d5118411b1105732fc11111bf660a76\MailClient.ExceptionUtils.ni.dll MailClient.ExceptionUtils.dll MailClient.ExceptionUtils.dll 1.0.0.0 MailClient.ExceptionUtils MailClient.ExceptionUtils 1.0.0.0 False False False False False Language Neutral jabber-net.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\jabber-net\c7fb7a96fa2f3f64716f73265cd2b6dc\jabber-net.ni.dll jabber-net.dll jabber-net.dll 7.0.0.2 Jabber-Net library jabber-net 7.0.0.2 False False False False False Language Neutral MailClient.Protocols.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Protocols\abc7ebaedb88c30f7046828785e0bded\MailClient.Protocols.ni.dll MailClient.Protocols.dll MailClient.Protocols.dll 7.0.26687.0 MailClient.Protocols MailClient.Protocols 7.0.26687.0 False False False False False Language Neutral Microsoft.Experimental.IO.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.E765800fb#\25948d09a56dfe064df89c83b4b1a21a\Microsoft.Experimental.IO.ni.dll Microsoft.Experimental.IO.dll Microsoft.Experimental.IO.dll 1.0.0.2 Microsoft.Experimental.IO Microsoft.Experimental.IO 1.0.0.2 False False False False False Language Neutral WinApi.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\WinApi\caf10e9161a53b5c86103f994c7afce5\WinApi.ni.dll WinApi.dll WinApi.dll 1.1.26687.0 WinApi WinApi 1.1.26687.0 False False False False False Language Neutral System.Core.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Core\a57805cc2d492d82e327b83ab24fad62\System.Core.ni.dll System.Core.dll System.Core.dll 4.6.1055.0 built by: NETFXREL2 .NET Framework Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) System.Data.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Data\24e2acca9a146b2ed3b28e52c7aeab31\System.Data.ni.dll system.data.dll system.data.dll 4.6.1082.0 built by: NETFXREL3STAGE .NET Framework Microsoft® .NET Framework 4.6.1082.0 False False False True False English (United States) System.Data.dll C:\windows\Microsoft.Net \assembly\GAC_32\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll system.data.dll system.data.dll 4.6.1082.0 built by: NETFXREL3STAGE .NET Framework Microsoft® .NET Framework 4.6.1082.0 False False False True False English (United States) WS2_32.dll C:\windows\syswow64\WS2_32.dll ws2_32.dll ws2_32.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Windows Socket 2.0 32-Bit DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) NSI.dll C:\windows\syswow64\NSI.dll nsi.dll nsi.dll 6.1.7600.16385 (win7_rtm.090713-1255) NSI User-mode interface DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) CRYPT32.dll C:\windows\syswow64\CRYPT32.dll CRYPT32.DLL CRYPT32.DLL.MUI 6.1.7601.18839 (win7sp1_gdr.150427-0707) Crypto API32 Microsoft® Windows® Operating System 6.1.7601.18839 False False False False False English (United States) MSASN1.dll C:\windows\syswow64\MSASN1.dll msasn1.dll msasn1.dll 6.1.7601.17514 (win7sp1_rtm.101119-1850) ASN.1 Runtime APIs Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) Xilium.CefGlue.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Xilium.CefGlue\cf81229cb04f0f946636a2e5b80f1322\Xilium.CefGlue.ni.dll Xilium.CefGlue.dll Xilium.CefGlue.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral libcef.DLL C:\Program Files (x86)\eM Client\libcef.DLL libcef libcef.dll 3.2623.1410.g88b9d69 Chromium Embedded Framework (CEF) Dynamic Link Library Chromium Embedded Framework (CEF) Dynamic Link Library 3.2623.1410.g88b9d69 False False False False False English (United States) PSAPI.DLL C:\windows\syswow64\PSAPI.DLL PSAPI PSAPI 6.1.7600.16385 (win7_rtm.090713-1255) Process Status Helper Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) WINSPOOL.DRV C:\windows\system32\WINSPOOL.DRV winspool.drv winspool.drv.mui 6.1.7600.16385 (win7_rtm.090713-1255) Windows Spooler Driver Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) COMDLG32.dll C:\windows\syswow64\COMDLG32.dll comdlg32 comdlg32.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Common Dialogs DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) COMCTL32.dll C:\windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_41e855142bd5705d\COMCTL32.dll comctl32 comctl32.DLL.MUI 6.10 (win7_rtm.090713-1255) User Experience Controls Library Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) SHELL32.dll C:\windows\syswow64\SHELL32.dll SHELL32 SHELL32.DLL.MUI 6.1.7601.23338 (win7sp1_ldr.160121-1716) Windows Shell Common Dll Microsoft® Windows® Operating System 6.1.7601.23338 False False False False False English (United States) OLEAUT32.dll C:\windows\syswow64\OLEAUT32.dll OLEAUT32.DLL 6.1.7601.19144 6.1.7601.19144 False False False False False English (United States) WINHTTP.dll C:\windows\system32\WINHTTP.dll winhttp.dll winhttp.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Windows HTTP Services Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) webio.dll C:\windows\system32\webio.dll webio.dll webio.dll.mui 6.1.7601.17514 (win7sp1_rtm.101119-1850) Web Transfer Protocols API Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) USERENV.dll C:\windows\syswow64\USERENV.dll userenv userenv.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Userenv Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) profapi.dll C:\windows\syswow64\profapi.dll PROFAPI.DLL PROFAPI.DLL 6.1.7600.16385 (win7_rtm.090713-1255) User Profile Basic API Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) urlmon.dll C:\windows\syswow64\urlmon.dll UrlMon.dll UrlMon.dll.mui 11.00.9600.17631 (winblue_r7.150111-1500) OLE32 Extensions for Win32 Internet Explorer 11.00.9600.17631 False False False False False English (United States) api-ms-win-downlevel-ole32-l1-1-0.dll C:\windows\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll apisetstub apisetstub 6.2.9200.16492 (win8_gdr_oobssr.130113-0015) ApiSet Stub DLL Microsoft® Windows® Operating System 6.2.9200.16492 False False False False False English (United States) api-ms-win-downlevel-shlwapi-l1-1-0.dll C:\windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll apisetstub apisetstub 6.2.9200.16492 (win8_gdr_oobssr.130113-0015) ApiSet Stub DLL Microsoft® Windows® Operating System 6.2.9200.16492 False False False False False English (United States) api-ms-win-downlevel-advapi32-l1-1-0.dll C:\windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll apisetstub apisetstub 6.2.9200.16492 (win8_gdr_oobssr.130113-0015) ApiSet Stub DLL Microsoft® Windows® Operating System 6.2.9200.16492 False False False False False English (United States) api-ms-win-downlevel-user32-l1-1-0.dll C:\windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll apisetstub apisetstub 6.2.9200.16492 (win8_gdr_oobssr.130113-0015) ApiSet Stub DLL Microsoft® Windows® Operating System 6.2.9200.16492 False False False False False English (United States) api-ms-win-downlevel-version-l1-1-0.dll C:\windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll apisetstub apisetstub 6.2.9200.16492 (win8_gdr_oobssr.130113-0015) ApiSet Stub DLL Microsoft® Windows® Operating System 6.2.9200.16492 False False False False False English (United States) api-ms-win-downlevel-normaliz-l1-1-0.dll C:\windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll apisetstub apisetstub 6.2.9200.16492 (win8_gdr_oobssr.130113-0015) ApiSet Stub DLL Microsoft® Windows® Operating System 6.2.9200.16492 False False False False False English (United States) normaliz.DLL C:\windows\syswow64\normaliz.DLL normaliz normaliz.dll 6.1.7600.16385 (win7_rtm.090713-1255) Unicode Normalization DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) iertutil.dll C:\windows\syswow64\iertutil.dll IeRtUtil.dll IeRtUtil.dll 11.00.9600.17631 (winblue_r7.150111-1500) Run time utility for Internet Explorer Internet Explorer 11.00.9600.17631 False False False False False English (United States) WININET.dll C:\windows\syswow64\WININET.dll wininet.dll wininet.dll.mui 11.00.9600.16428 (winblue_gdr.131013-1700) Internet Extensions for Win32 Internet Explorer 11.00.9600.16428 False False False False False English (United States) dhcpcsvc.DLL C:\windows\system32\dhcpcsvc.DLL dhcpcsvc.dll dhcpcsvc.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) DHCP Client Service Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) WTSAPI32.dll C:\windows\system32\WTSAPI32.dll wtsapi32.dll wtsapi32.dll 6.1.7601.17514 (win7sp1_rtm.101119-1850) Windows Remote Desktop Session Host Server SDK APIs Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) OLEACC.dll C:\windows\system32\OLEACC.dll OLEACC OLEACC.DLL 7.0.0.0 (win7sp1_gdr.110826-1504) Active Accessibility Core Component Microsoft® Windows® Operating System 6.1.7601.17676 False False False False False Language Neutral WINMM.dll C:\windows\system32\WINMM.dll winmm.dll WINMM.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) MCI API DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) Secur32.dll C:\windows\system32\Secur32.dll secur32.dll secur32.dll 6.1.7601.23497 (win7sp1_ldr.160708-0600) Security Support Provider Interface Microsoft® Windows® Operating System 6.1.7601.23497 False False False False False English (United States) IPHLPAPI.DLL C:\windows\system32\IPHLPAPI.DLL iphlpapi.dll iphlpapi.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) IP Helper API Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) WINNSI.DLL C:\windows\system32\WINNSI.DLL winnsi.dll winnsi.dll 6.1.7600.16385 (win7_rtm.090713-1255) Network Store Information RPC interface Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) nlssorting.dll C:\Windows\Microsoft.NET \Framework\v4.0.30319\nlssorting.dll nlssorting.dll nlssorting.dll 4.6.1055.0 built by: NETFXREL2 Microsoft Collation Support Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) System.Configuration.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Configuration\6b3bc806e6d6a2c73c6d9f1429395698\System.Configuration.ni.dll System.Configuration.dll System.Configuration.dll 4.6.1055.0 built by: NETFXREL2 System.Configuration.dll Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) System.Xml.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Xml\36599a72e79974ff4c004c43df9fce2b\System.Xml.ni.dll System.Xml.dll System.Xml.dll 4.6.1067.0 built by: NETFXREL3STAGE .NET Framework Microsoft® .NET Framework 4.6.1067.0 False False False True False English (United States) credssp.dll C:\windows\system32\credssp.dll credssp.dll credssp.dll 6.1.7601.23497 (win7sp1_ldr.160708-0600) Credential Delegation Security Package Microsoft® Windows® Operating System 6.1.7601.23497 False False False False False English (United States) comctl32.dll C:\windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18837_none_ec86b8d6858ec0bc\comctl32.dll comctl32 comctl32.DLL.MUI 6.10 (win7_rtm.090713-1255) User Experience Controls Library Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) dwmapi.dll C:\windows\system32\dwmapi.dll dwmapi.dll dwmapi.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Desktop Window Manager API Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) gdiplus.dll C:\windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23508_none_5c028c09a01213b0\gdiplus.dll gdiplus gdiplus 6.1.7601.23508 (win7sp1_ldr.160729-0600) Microsoft GDI+ Microsoft® Windows® Operating System 6.1.7601.23508 False False False False False English (United States) System.Runtime.Remoting.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Runt73a1fc9d#\88294208527e99146987be30c22d1d37\System.Runtime.Remoting.ni.dll System.Runtime.Remoting.dll System.Runtime.Remoting.dll 4.6.1055.0 built by: NETFXREL2 Microsoft .NET Runtime Object Remoting Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) mswsock.dll C:\windows\system32\mswsock.dll mswsock.dll mswsock.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Windows Sockets 2.0 Service Provider Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) wshtcpip.dll C:\windows\System32\wshtcpip.dll wshtcpip.dll wshtcpip.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Winsock2 Helper DLL (TL/IPv4) Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) wship6.dll C:\windows\System32\wship6.dll wship6.dll wship6.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Winsock2 Helper DLL (TL/IPv6) Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) RpcRtRemote.dll C:\windows\system32\RpcRtRemote.dll RpcRtRemote.dll RpcRtRemote.dll 6.1.7601.17514 (win7sp1_rtm.101119-1850) Remote RPC Extension Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) diasymreader.dll C:\Windows\Microsoft.NET \Framework\v4.0.30319\diasymreader.dll diasymreader.dll diasymreader.dll 14.00.1055.0 built by: NETFXREL2 Dia based SymReader Microsoft® Visual Studio® 12 CTP 14.00.1055.0 False False False False False English (United States) PROPSYS.dll C:\windows\system32\PROPSYS.dll propsys.dll propsys.dll.mui 7.00.7600.16385 (win7_rtm.090713-1255) Microsoft Property System Windows® Search 7.00.7600.16385 False False False False False English (United States) CLBCatQ.DLL C:\windows\syswow64\CLBCatQ.DLL CLBCATQ.DLL CLBCATQ.DLL 2001.12.8530.16385 (win7_rtm.090713-1255) COM+ Configuration Catalog Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) ntmarta.dll C:\windows\system32\ntmarta.dll ntmarta.dll ntmarta.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Windows NT MARTA provider Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) WLDAP32.dll C:\windows\syswow64\WLDAP32.dll WLDAP32.DLL WLDAP32.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) Win32 LDAP API DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) api-ms-win-downlevel-advapi32-l2-1-0.dll C:\windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll apisetstub apisetstub 6.2.9200.16492 (win8_gdr_oobssr.130113-0015) ApiSet Stub DLL Microsoft® Windows® Operating System 6.2.9200.16492 False False False False False English (United States) SETUPAPI.dll C:\windows\syswow64\SETUPAPI.dll SETUPAPI.DLL SETUPAPI.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) Windows Setup API Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) CFGMGR32.dll C:\windows\syswow64\CFGMGR32.dll cfgmgr32.dll CFGMGR32.DLL 6.1.7601.17621 (win7sp1_gdr.110523-2108) Configuration Manager DLL Microsoft® Windows® Operating System 6.1.7601.17621 False False False False False English (United States) DEVOBJ.dll C:\windows\syswow64\DEVOBJ.dll devinfoset.dll devinfoset.DLL 6.1.7601.17621 (win7sp1_gdr.110523-2108) Device Information Set DLL Microsoft® Windows® Operating System 6.1.7601.17621 False False False False False English (United States) apphelp.dll C:\windows\system32\apphelp.dll Apphelp Apphelp 6.1.7600.16385 (win7_rtm.090713-1255) Application Compatibility Client Library Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) System.Data.SQLite.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Data.SQLite\7c91294a44e5b6c7bec89a423b8f5dba\System.Data.SQLite.ni.dll System.Data.SQLite.dll System.Data.SQLite.dll 1.0.84.2 System.Data.SQLite Core System.Data.SQLite 1.0.84.2 False False False False False Language Neutral sqlite3.dll C:\Program Files (x86)\eM Client\SQLite\x86\sqlite3.dll False False False False False api-ms-win-core-synch-l1-2-0.DLL C:\windows\system32\api-ms-win-core-synch-l1-2-0.DLL apisetstub apisetstub 10.0.10586.9 (th2_release.151110-1756) ApiSet Stub DLL Microsoft® Windows® Operating System 10.0.10586.9 False False False False False English (United States) Microsoft.Search.Interop.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.Sd25cd4a4#\2c282fd285d661ecaaa8a78ccf50f902\Microsoft.Search.Interop.ni.dll Microsoft.Search.Interop Microsoft.Search.Interop.dll 1.0.0.0 Assembly imported from type library ‘SearchAPILib’. 1.0.0.0 False False False False False Invariant Language (Invariant Country) System.Transactions.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Transactions\dc2eb8260dcff0680cb9c540180ca0fe\System.Transactions.ni.dll system.transactions.dll system.transactions.dll 4.6.1055.0 built by: NETFXREL2 .NET Framework Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) System.Transactions.dll C:\windows\Microsoft.Net \assembly\GAC_32\System.Transactions\v4.0_4.0.0.0__b77a5c561934e089\System.Transactions.dll system.transactions.dll system.transactions.dll 4.6.1055.0 built by: NETFXREL2 .NET Framework Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) System.EnterpriseServices.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Ente96d83b35#\3943736da92ef14ff500bcddff286994\System.EnterpriseServices.ni.dll System.EnterpriseServices.dll System.EnterpriseServices.dll 4.6.1055.0 built by: NETFXREL2 Microsoft .NET Services Support Infrastructure Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) System.EnterpriseServices.Wrapper.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Ente96d83b35#\3943736da92ef14ff500bcddff286994\System.EnterpriseServices.Wrapper.dll System.EnterpriseServices.Wrapper.dll System.EnterpriseServices.Wrapper.dll 4.6.1055.0 built by: NETFXREL2 Microsoft .NET Services Native Thunks Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) System.EnterpriseServices.Wrapper.dll C:\windows\Microsoft.Net \assembly\GAC_32\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll System.EnterpriseServices.Wrapper.dll System.EnterpriseServices.Wrapper.dll 4.6.1055.0 built by: NETFXREL2 Microsoft .NET Services Native Thunks Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) MailClient.Threading.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Threading\81e9b6ca1b002276a8952b7e56e84f93\MailClient.Threading.ni.dll MailClient.Threading.dll MailClient.Threading.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral MailClient.Streams.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Streams\83e5a9f81da1e06bad99a47de7815fd4\MailClient.Streams.ni.dll MailClient.Streams.dll MailClient.Streams.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral MailClient.IM.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.IM\b60fd5452aaab001e3d35e44ceaf59b3\MailClient.IM.ni.dll MailClient.IM.dll MailClient.IM.dll 7.0.26687.0 MailClient.IM MailClient.IM 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Mail.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.1fd7a4e5#\c59eff237ce878d4e41de7f2e44bad23\MailClient.Storage.Mail.ni.dll MailClient.Storage.Mail.dll MailClient.Storage.Mail.dll 7.0.26687.0 MailClient.Storage.Mail MailClient.Storage.Mail 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Folders.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.b2c914c9#\54aefcce46c485ad212d69ade6d4d46c\MailClient.Storage.Folders.ni.dll MailClient.Storage.Folders.dll MailClient.Storage.Folders.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral MailClient.Commands.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Commands\138168ae54acfa13f294ebf879b476e2\MailClient.Commands.ni.dll MailClient.Commands.dll MailClient.Commands.dll 7.0.26687.0 MailClient.Commands MailClient.Commands 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Attachment.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.5331ec95#\c40e5ea425435cc4963b4ed87ed8be87\MailClient.Storage.Attachment.ni.dll MailClient.Storage.Attachment.dll MailClient.Storage.Attachment.dll 7.0.26687.0 MailClient.Storage.Attachment MailClient.Storage.Attachment 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Schedule.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.6df617c9#\ddd93c8e5eb8815e59c8cea1b1ab81da\MailClient.Storage.Schedule.ni.dll MailClient.Storage.Schedule.dll MailClient.Storage.Schedule.dll 7.0.26687.0 MailClient.Storage.Objects MailClient.Storage.Objects 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Contact.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.f2c61d2c#\47b668bf1699b9d9a2bb1afd17c8c7a6\MailClient.Storage.Contact.ni.dll MailClient.Storage.Contact.dll MailClient.Storage.Contact.dll 7.0.26687.0 MailClient.Storage.Contact MailClient.Storage.Contact 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.IM.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.9a79bc48#\3b24db0f62048d70efc96977cd6da2b5\MailClient.Storage.IM.ni.dll MailClient.Storage.IM.dll MailClient.Storage.IM.dll 7.0.26687.0 MailClient.Storage.IM MailClient.Storage.IM 7.0.26687.0 False False False False False Language Neutral MailClient.Schedule.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Schedule\4b3ae98f5dbac1d2e842e2f1821aae22\MailClient.Schedule.ni.dll MailClient.Schedule.dll MailClient.Schedule.dll 7.0.26687.0 MailClient.Objects MailClient.Objects 7.0.26687.0 False False False False False Language Neutral SystemCoreTimeZone.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\SystemCoreTimeZone\aaceee9d81b138270d60367b9daef244\SystemCoreTimeZone.ni.dll SystemCoreTimeZone.dll SystemCoreTimeZone.dll 1.0.0.4 SystemCoreTimeZone SystemCoreTimeZone 1.0.0.4 False False False False False Language Neutral clrjit.dll C:\Windows\Microsoft.NET \Framework\v4.0.30319\clrjit.dll clrjit.dll clrjit.dll 4.6.1076.0 built by: NETFXREL3STAGE Microsoft .NET Runtime Just-In-Time Compiler Microsoft® .NET Framework 4.6.1076.0 False False False True False English (United States) MailClient.Contact.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Contact\7d4a86a08bdc7902b49fa7c2aeb4ba41\MailClient.Contact.ni.dll MailClient.Contact.dll MailClient.Contact.dll 7.0.26687.0 MailClient.Contact MailClient.Contact 7.0.26687.0 False False False False False Language Neutral MailClient.Attachment.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.ff7bbfa2#\0056b9e40cfeaade3db649dbb336a628\MailClient.Attachment.ni.dll MailClient.Attachment.dll MailClient.Attachment.dll 0.0.0.0 0.0.0.0 False False False False False Language Neutral MailClient.Storage.Category.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.4824fbfc#\484033d4d5fd1eebe739af489903dca6\MailClient.Storage.Category.ni.dll MailClient.Storage.Category.dll MailClient.Storage.Category.dll 7.0.26687.0 MailClient.Storage.Category MailClient.Storage.Category 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Certificate.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.d8481e79#\84eb3b12b7a6a3b51f892bd1dd8b6984\MailClient.Storage.Certificate.ni.dll MailClient.Storage.Certificate.dll MailClient.Storage.Certificate.dll 7.0.26687.0 MailClient.Storage.Template MailClient.Storage.Template 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Security.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.c1d859fa#\996ff1bdbce207e03244f8f9e77d1551\MailClient.Storage.Security.ni.dll MailClient.Storage.Security.dll MailClient.Storage.Security.dll 7.0.26687.0 MailClient.Storage.Security MailClient.Storage.Security 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Snippet.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.c3eb0b89#\f1e74c7a01ac9931981ec8e3b1760198\MailClient.Storage.Snippet.ni.dll MailClient.Storage.Snippet.dll MailClient.Storage.Snippet.dll 7.0.26687.0 MailClient.Storage.Signature MailClient.Storage.Signature 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Template.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.319ca19c#\b71eaa6e9a9ad92c354ae97ad57713c2\MailClient.Storage.Template.ni.dll MailClient.Storage.Template.dll MailClient.Storage.Template.dll 7.0.26687.0 MailClient.Storage.Template MailClient.Storage.Template 7.0.26687.0 False False False False False Language Neutral MailClient.Storage.Rule.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.1fe73d22#\b7c28b6ad31dc9ee0ad371cdb3181f95\MailClient.Storage.Rule.ni.dll MailClient.Storage.Rule.dll MailClient.Storage.Rule.dll 7.0.26687.0 MailClient.Storage.Widget MailClient.Storage.Widget 7.0.26687.0 False False False False False Language Neutral NLAapi.dll C:\windows\system32\NLAapi.dll nlaapi.dll nlaapi.dll 6.1.7601.18685 (win7sp1_gdr.141205-1623) Network Location Awareness 2 Microsoft® Windows® Operating System 6.1.7601.18685 False False False False False English (United States) audioses.dll C:\windows\system32\audioses.dll AudioSession AudioSes.Dll.MUI 6.1.7600.16385 (win7_rtm.090713-1255) Audio Session Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) MMDevAPI.DLL C:\windows\system32\MMDevAPI.DLL MMDeviceAPI MMDevAPI.Dll.MUI 6.1.7600.16385 (win7_rtm.090713-1255) MMDevice API Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) dhcpcsvc6.DLL C:\windows\system32\dhcpcsvc6.DLL dhcpcsvc6.dll dhcpcsvc6.dll.mui 6.1.7601.17970 (win7sp1_gdr.121009-0412) DHCPv6 Client Microsoft® Windows® Operating System 6.1.7601.17970 False False False False False English (United States) WINTRUST.dll C:\windows\syswow64\WINTRUST.dll WINTRUST.DLL WINTRUST.DLL 6.1.7601.18839 (win7sp1_gdr.150427-0707) Microsoft Trust Verification APIs Microsoft® Windows® Operating System 6.1.7601.18839 False False False False False English (United States) Accessibility.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Accessibility\329cc606515169bfd06a4d2529b99a31\Accessibility.ni.dll UNKNOWN_FILE UNKNOWN_FILE 4.6.1055.0 built by: NETFXREL2 .NET Framework Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) WindowsCodecs.dll C:\windows\system32\WindowsCodecs.dll WindowsCodecs WindowsCodecs 6.2.9200.21830 (win8_ldr.160407-0600) Microsoft Windows Codecs Library Microsoft® Windows® Operating System 6.2.9200.21830 False False False False False English (United States) Xilium.CefGlue.WindowsForms.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Xilium.CefG0f485e28#\3df26ae8bd5134127eef7ad4a4de6782\Xilium.CefGlue.WindowsForms.ni.dll Xilium.CefGlue.WindowsForms.dll Xilium.CefGlue.WindowsForms.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral napinsp.dll C:\windows\system32\napinsp.dll napinsp.dll napinsp.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) E-mail Naming Shim Provider Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) pnrpnsp.dll C:\windows\system32\pnrpnsp.dll pnrpnsp.dll pnrpnsp.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) PNRP Name Space Provider Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) DNSAPI.dll C:\windows\system32\DNSAPI.dll dnsapi dnsapi 6.1.7600.16385 (win7_rtm.090713-1255) DNS Client API DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) winrnr.dll C:\windows\System32\winrnr.dll winrnr winrnr 6.1.7600.16385 (win7_rtm.090713-1255) LDAP RnR Provider DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) WLIDNSP.DLL C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL WlidNSP.dll WlidNSP.dll 7.250.4232.0 Microsoft® Windows Live ID Namespace Provider Microsoft® CoReXT 7.250.4232.0 False False False False False English (United States) Microsoft.VisualBasic.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.V9921e851#\2c4f2941220c9d637c098649ead31b91\Microsoft.VisualBasic.ni.dll Microsoft.VisualBasic.DLL Microsoft.VisualBasic.DLL 14.6.1055.0 built by: NETFXREL2 Visual Basic Runtime Library Microsoft® .NET Framework 14.6.1055.0 False False False True False English (United States) WindowsAPICodePack.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\WindowsAPICodePack\5404cb66f9a67e50e1b7980fdae5e8cb\WindowsAPICodePack.ni.dll WindowsAPICodePack.dll WindowsAPICodePack.dll 1.0.1.0 WindowsAPICodePack WindowsAPICodePack 1.0.1.0 False False False False False Language Neutral gameux.dll C:\Windows\SysWOW64\gameux.dll gameux.dll gameux.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Games Explorer Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) XmlLite.dll C:\Windows\SysWOW64\XmlLite.dll XmlLite.dll XmlLite.dll 1.3.1001.0 Microsoft XmlLite Library Microsoft XML Core Services 1.3.1001.0 False False False False False Language Neutral wer.dll C:\Windows\SysWOW64\wer.dll wer.dll wer.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Windows Error Reporting DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) shdocvw.dll C:\windows\System32\shdocvw.dll SHDOCVW.DLL SHDOCVW.DLL.MUI 6.1.7601.18222 (win7sp1_gdr.130725-1535) Shell Doc Object and Control Library Microsoft® Windows® Operating System 6.1.7601.18222 False False False False False English (United States) LINKINFO.dll C:\windows\system32\LINKINFO.dll LINKINFO LINKINFO.DLL 6.1.7600.16385 (win7_rtm.090713-1255) Windows Volume Tracking Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) ntshrui.dll C:\windows\system32\ntshrui.dll ntshrui ntshrui.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Shell extensions for sharing Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) srvcli.dll C:\windows\system32\srvcli.dll SRVCLI.DLL SRVCLI.DLL 6.1.7601.17514 (win7sp1_rtm.101119-1850) Server Service Client DLL Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) cscapi.dll C:\windows\system32\cscapi.dll cscapi.dll cscapi.dll 6.1.7601.17514 (win7sp1_rtm.101119-1850) Offline Files Win32 API Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) slc.dll C:\windows\system32\slc.dll slcdll.dll slcdll.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Software Licensing Client Dll Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) MailClient.Sasl.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Sasl\13c92cea39d372e242fd56f30db1d8f9\MailClient.Sasl.ni.dll MailClient.Sasl.dll MailClient.Sasl.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral WINSTA.dll C:\windows\system32\WINSTA.dll winsta winsta.dll 6.1.7601.18540 (win7sp1_gdr.140716-1508) Winstation Library Microsoft® Windows® Operating System 6.1.7601.18540 False False False False False English (United States) MailClient.Imap.Base.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.Imap.Base\5696b3c2ca44d2782afd2999c7eed756\MailClient.Imap.Base.ni.dll MailClient.Imap.Base.dll MailClient.Imap.Base.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral rasadhlp.dll C:\windows\system32\rasadhlp.dll rasadhlp.dll rasadhlp.dll 6.1.7600.16385 (win7_rtm.090713-1255) Remote Access AutoDial Helper Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) fwpuclnt.dll C:\windows\System32\fwpuclnt.dll fwpuclnt.dll fwpuclnt.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) FWP/IPsec User-Mode API Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) Google.GData.Client.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Google.GData.Client\17a7d3cc7457782905284c94de669342\Google.GData.Client.ni.dll Google.GData.Client.dll Google.GData.Client.dll 2.2.0.0 Google Data API Core Library Google GData Client Libraries 2.2.0.0 False False False False False Language Neutral Google.GData.Contacts.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Google.GDat88526e68#\2d7efe8085e8acc9b33fb82bd509dad3\Google.GData.Contacts.ni.dll Google.GData.Contacts.dll Google.GData.Contacts.dll 2.2.0.0 Google Data API Contacts Library Google GData Client Libraries 2.2.0.0 False False False False False Language Neutral Google.GData.Extensions.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\Google.GDatc9e696b1#\a2d1ed8de7a3defff619008740ab9c16\Google.GData.Extensions.ni.dll Google.GData.Extensions.dll Google.GData.Extensions.dll 2.2.0.0 Google Data API Extensions Library Google GData Client Libraries 2.2.0.0 False False False False False Language Neutral rasapi32.dll C:\windows\system32\rasapi32.dll rasapi32.dll rasapi32.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Remote Access API Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) rasman.dll C:\windows\system32\rasman.dll Rasman.dll Rasman.dll 6.1.7600.16385 (win7_rtm.090713-1255) Remote Access Connection Manager Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) rtutils.dll C:\windows\system32\rtutils.dll RTUTILS.DLL RTUTILS.DLL 6.1.7601.17514 (win7sp1_rtm.101119-1850) Routing Utilities Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) schannel.dll C:\windows\SysWOW64\schannel.dll schannel.dll schannel.dll 6.1.7601.23497 (win7sp1_ldr.160708-0600) TLS / SSL Security Provider Microsoft® Windows® Operating System 6.1.7601.23497 False False False False False English (United States) MailClient.Protocols.Exchange.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.d5b8df6b#\2219437efa238708b35e79dd23b98b3b\MailClient.Protocols.Exchange.ni.dll MailClient.Protocols.Exchange.dll MailClient.Protocols.Exchange.dll 7.0.26687.0 MailClient.Protocols.Exchange MailClient.Protocols.Exchange 7.0.26687.0 False False False False False Language Neutral System.DirectoryServices.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Dired13b18a9#\36faff618ea6f18312848d98edbd8657\System.DirectoryServices.ni.dll System.DirectoryServices.dll System.DirectoryServices.dll 4.6.1055.0 built by: NETFXREL2 .NET Framework Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) ntdsapi.dll C:\windows\system32\ntdsapi.dll ntdsapi.dll ntdsapi.dll 6.1.7600.16385 (win7_rtm.090713-1255) Active Directory Domain Services API Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) Netapi32.dll C:\windows\system32\Netapi32.dll NetApi32.DLL NetApi32.DLL 6.1.7601.17887 (win7sp1_gdr.120704-0720) Net Win32 API DLL Microsoft® Windows® Operating System 6.1.7601.17887 False False False False False English (United States) netutils.dll C:\windows\system32\netutils.dll NETUTILS.DLL NETUTILS.DLL 6.1.7601.17514 (win7sp1_rtm.101119-1850) Net Win32 API Helpers DLL Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) wkscli.dll C:\windows\system32\wkscli.dll WKSCLI.DLL WKSCLI.DLL 6.1.7601.17514 (win7sp1_rtm.101119-1850) Workstation Service Client DLL Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) LOGONCLI.DLL C:\windows\system32\LOGONCLI.DLL LOGONCLI.DLL LOGONCLI.DLL 6.1.7601.17514 (win7sp1_rtm.101119-1850) Net Logon Client DLL Microsoft® Windows® Operating System 6.1.7601.17514 False False False False False English (United States) MailClient.Protocols.Discovery.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.20757bfa#\ae58208d3edbe16e5eb2ea270e9ecf3c\MailClient.Protocols.Discovery.ni.dll MailClient.Protocols.Discovery.dll MailClient.Protocols.Discovery.dll 7.0.26687.0 MailClient.Protocols.Discovery MailClient.Protocols.Discovery 7.0.26687.0 False False False False False Language Neutral System.Web.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\System.Web\458817680c33d8cdf0e033cd65772906\System.Web.ni.dll System.Web.dll System.Web.dll 4.6.1055.0 built by: NETFXREL2 System.Web.dll Microsoft® .NET Framework 4.6.1055.0 False False False True False English (United States) ncrypt.dll C:\windows\system32\ncrypt.dll ncrypt.dll ncrypt.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Windows cryptographic library Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) bcrypt.dll C:\windows\system32\bcrypt.dll bcrypt.dll bcrypt.dll 6.1.7600.16385 (win7_rtm.090713-1255) Windows Cryptographic Primitives Library (Wow64) Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) bcryptprimitives.dll C:\windows\SysWOW64\bcryptprimitives.dll bcryptprimitives.dll bcryptprimitives.dll 6.1.7601.23451 (win7sp1_ldr.160511-0600) Windows Cryptographic Primitives Library Microsoft® Windows® Operating System 6.1.7601.23451 False False False False False English (United States) GPAPI.dll C:\windows\system32\GPAPI.dll gpapi.dll gpapi.dll.mui 6.1.7601.23452 (win7sp1_ldr.160512-0600) Group Policy Client API Microsoft® Windows® Operating System 6.1.7601.23452 False False False False False English (United States) netlib.Dns.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\netlib.Dns\880afbaddc24757d1c5d33d74b88245c\netlib.Dns.ni.dll netlib.Dns.dll netlib.Dns.dll 1.1.0.0 netlib.Dns The ASP Emporium (http://www.aspemporium.com/) ; 1.1.0.0 False False False False False Language Neutral MailClient.Storage.Widget.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.a758b3a0#\8557b564ae6560a835cb1f25f4e76af4\MailClient.Storage.Widget.ni.dll MailClient.Storage.Widget.dll MailClient.Storage.Widget.dll 7.0.26687.0 MailClient.Storage.Widget MailClient.Storage.Widget 7.0.26687.0 False False False False False Language Neutral tiptsf.dll C:\Program Files (x86)\Common Files\microsoft shared\ink\tiptsf.dll TipTsf.dll TipTsf.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) Tablet PC Input Panel Text Services Framework Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) explorerframe.dll C:\windows\system32\explorerframe.dll ExplorerFrame ExplorerFrame.dll.mui 6.1.7600.16385 (win7_rtm.090713-1255) ExplorerFrame Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) DUser.dll C:\windows\system32\DUser.dll DUser DUser.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) Windows DirectUser Engine Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) DUI70.dll C:\windows\system32\DUI70.dll DUI70 DUI70.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) Windows DirectUI Engine Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) mscms.dll C:\windows\system32\mscms.dll MSCMS.DLL MSCMS.DLL.MUI 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Color Matching System DLL Microsoft® Windows® Operating System 6.1.7600.16385 False False False False False English (United States) MailClient.HtmlConversion.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\MailClient.2d2de33e#\90d55544034cd1a8f29eb32e3d940471\MailClient.HtmlConversion.ni.dll MailClient.HtmlConversion.dll MailClient.HtmlConversion.dll 7.0.26687.0 MailClient.HtmlConversion MailClient.HtmlConversion 7.0.26687.0 False False False False False Language Neutral IvanAkcheurov.NClassify.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\IvanAkcheurda66b2d7#\65c269c2dafbc8b0b18cda3ed47bcd97\IvanAkcheurov.NClassify.ni.dll IvanAkcheurov.NClassify.dll IvanAkcheurov.NClassify.dll 0.2.1.1 IvanAkcheurov.NClassify NTextCat 0.2.1.1 False False False False False Language Neutral IvanAkcheurov.NTextCat.Lib.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\IvanAkcheur7ace2bcd#\8653101f0b08b6156a2f36f361839114\IvanAkcheurov.NTextCat.Lib.ni.dll IvanAkcheurov.NTextCat.Lib.dll IvanAkcheurov.NTextCat.Lib.dll 0.2.1.1 IvanAkcheurov.NTextCatLib NTextCat 0.2.1.1 False False False False False Language Neutral NHunspell.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\NHunspell\1f80d9a67ad4655df300dc33d8e9e2ef\NHunspell.ni.dll NHunspell.dll NHunspell.dll 7.0.26687.0 7.0.26687.0 False False False False False Language Neutral Hunspellx86.dll C:\Program Files (x86)\eM Client\Hunspellx86.dll Hunspell 1,2,5554,16953 Hunspell Native Code DLL NHunspell Spell Checker 1.2.5554.16953 False False False False False German (Germany) ExCSS.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\ExCSS\d613c10fa5664f248cf6e37b57fd39a6\ExCSS.ni.dll ExCSS.dll ExCSS.dll 1.0.0.0 ExCSS ExCSS 1.0.0.0 False False False False False Language Neutral SgmlReader.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\SgmlReader\e2e1de79269795179b90da12f8675c06\SgmlReader.ni.dll SgmlReader.dll SgmlReader.dll 7.0.26687.0 SgmlReader SgmlReader 7.0.26687.0 False False False False False Language Neutral
