How can I force eM Client (for Winows 11) to stay in Offline Mode permanently? I have noticed that even after manually switching to Offline Mode, the application automatically reverts to Online Mode. My goal is to keep the app offline indefinitely so I can compose emails and manually choose exactly when to send them, allowing me to amend them if necessary, before sending. Is there a setting or registry tweak to prevent the app from automatically reconnecting?
That’s really strange its going back online as It normally does stay offline until you either click the “Red offline button” or go to “Menu / File / Work offline” and uncheck it.
Suggest them you then just click the “Wifi or LAN” icon in the tray and disable until your ready to send mail.
Good idea. The problem is, I’ll have no internet access for anything else … but I appreciate the reply. Thanks, Cyberzork.
