W11 Pro emClient update
I’m not satisfied with the update experience of emClient 11 from one version to another. The installer provides reinstalling or removing but no update. The update within emClient 11 takes a long time I don’t know if there is progress. On macOS everything is fine.
Greetings from BigR
If you install the MSIX app installer version either from the either from release history page or official download page it automatically updates itself and no need to uninstall and reinstall. It only updates the changes.
From my own experience with Windows 11 Pro it’s sometimes a bit slow to update the changes with the MSIX version, but it does update. So be patient if you don’t see the new ver changes instantly.
I tried to install the newest update via the history page. There is some improvement but no real solution on W11 Pro. I had to remove my installation on W11 Pro, waiting for an update installation is no option for me.
I turned off all uninstaller programs on W11 Pro, this gives a better installation experience of emClient 11. I hope this is the solution.
Greetings from BigR
