1)Ik mis een snelkoppeling op de hoofdwerkbalk om de attachements vlot te openen.
De header bovenaan de geopende mail neemt teveel plaats in.
2) De zijschuifbalken zijn te dun om gemakkelijk met de muis te kunnen scrollen.
Voor de rest een zeer goede e-mailclient, ook snel op kleine trage pc’s.
To open an attachment, double-click on it. There are other options but that just seems the easiest.
You can change to another theme in Menu > Tools > Settings > Appearance > Themes. Most of them have wider scroll bars. To change the width of the scroll bar in the Modern Theme, you will need to edit the file.
To do that go to Menu > Tools > Settings > Appearance > Themes and select the theme you want to edit. Click on Advanced > Save current theme as . . .
Go to the location where you saved the theme and edit it with a text editor like Notepad.
Change the line:
False
to:
True
Save the file.
In eM Client go to Menu > Tools > Settings > Appearance > Themes and click on Import. Select the file you just edited in Notepad.
You will find the edited theme at the END of the list of themes.
