Very regular error messages
This is an issue with Google, as you exceeded their size limit.  It is not an eM Client problem.  If this keeps appearing, the email may be stuck in your outbox.  The outbox is a local folder, so make sure you have the option selected to display them (menu/tools/settings/general and in the general section, check “Show local folders”).  Then you can delete the offending message.
