Verknüpfung im Kontexmenü Shell:sendto
Senden an (Kontexmenü) wird emClient nicht angezeigt Dateien direkt mit emClient Mail versenden. Verknüpfung im Kontexmenü vorhanden.
The “Send to” option (context menu) does not display emClient. Sending files directly with emClient Mail is not possible. A link is available in the context menu.
If you mean you carm’t send an attachment from eM Client directly to a receipient in the “Attachments” section, you can “right click on the file” and click “Forward” which will open a new mail window with that attachment ready to send.
If you mean you cannot send a file attachment directly to an email using either File Explorer in Windows or Finder in Mac, then see the below. If you don’t have the below Send To or Share options available when you right click then you have some sort of installation or OS problem.
For Windows 10 using “File Explorer” after right clicking on the file you click “Send to” and click “Mail receipient” in the dropdown menu, which will then open eM Client and automatically attach the file as long as you have eM Client set as the default mail client in the OS.
For Windows 11 using “File Explorer” after right clicking on the file, you first click “Show More Options” in the dropdown menu, and then you will see the “Send to / Mail recipient” which will open eM Client and automatically attach the file as long as you have eM Client set as the default mail client in the OS as per the below first two screenshot examples below.
For Mac OS 27 using “Finder” you right click on a file and click “Share” and click “eM Client” on the window that appears which will open eM Client and attach the file as long as you have eM Client set as default in the OS as per the third & fourth screenshot examples below.
“Windows 11 Send to / Mail receipient example” using File Explorer
“Mac OS 27 Share to / eM Client example” using Finder
