verificando integridade com o banco de dad
System.ApplicationException: database disk image is malformed
Line: 15
DELETE FROM mail_data.LocalMailContents WHERE NOT EXISTS (SELECT id FROM mail_index.MailItems WHERE id=mail_data.LocalMailContents.id);
   em MailClient.Storage.Data.DbRepository1.ImportFromResource(IDbConnection connection, Stream myStream, CancellationToken token)    em MailClient.Storage.Data.DbRepository1.ImportFromManifestResource(String resourceName, CancellationToken token)
   em MailClient.Storage.Data.DbRepository1.Repair(RepairMode mode, CancellationToken token) &nbsp; &nbsp;em MailClient.Accounts.ItemRepositories.Repair(RepairMode mode, CancellationToken token) &nbsp; &nbsp;em DbRepair.ConsistencyChecker.CheckConsistencyForAccount(String accountDirectory, RepairMode mode, CancellationToken token) &nbsp; &nbsp;em DbRepair.ConsistencyChecker.\<\>c\_\_DisplayClass2\_0.<check>b__0(String p)<br alt="" name="" rel="" target="" title="" type="" value=""> em DbRepair.PerAccountExecutor.Execute(String dataStoreLocation, Func2 action)
em DbRepair.ConsistencyChecker.Check(RepairMode mode, CancellationToken token)
em DbRepair.CheckingProcess.Check(CancellationToken token)
Data:
ResourceName: MailClient.Storage.Mail.Data.DbMailRepository.consistency.sql
DatastoreLocation: C:\Users\CRACHAS\AppData\Roaming\eM Client<br alt="" name="" rel="" target="" title="" type="" value="">
Hi Cleber,
From what I see from the log, your database is most likely corrupted.
Please note that you have to close eM Client before making any changes in the database location, proceeding without closed eM Client can cause the database corruption.
In case you have all your data saved on servers you can simply delete the database folder and start eM Client.
It will create empty database where you can set your accounts again. All your data should be pushed to eM Client automatically then.
You can find eM Client database here:
C:\Users%Current User%\AppData\Roaming\eM Client
To locate AppData folder you need to view hidden folders in Windows: https://support.microsoft.com/en-us/help/14201/windows-show-hidden-files
In case that you have an account set as POP3 or locally stored data, you can restore the old database backup if you made any in Menu > File > Restore.
Russel
