Using tab key in schedule event window bypasses category and calendar option.
What version of eM Client are you using?
Beta 5. I was using ver 4 and the tab key worked the same way.
Another quirk I noticed with the tab key. On a new message window, I can tab between To, cc, bcc, subject and then to the message body as expected. But when I try to tab back (shift-tab), I can tab up from Subject to bcc, to cc, to To, but not from the message body to the subject. It’s a minor inconvenience, but just seems inconsistent.
Thanks for reporting - we will try to fix it ASAP.
Thanks for your reply. I have used too many email programs
to mention. This is the best one yet.
I have used too many email programs to mention. This is the best one yet.
