Yeah, not sure. It has been many years since I used Access. As far as I remember SendObject should work with your choice of email client as long as it has all it’s defaults set.
However…
(I am on Windows 10.)
I go to .mapimail
It says there is not app associated with it.
There is a “+” to the right, that presumably allows you specify apporpriate app.
It says “there is no installed app” for .mapimail
Please note that eM IS installed, and is the default mail client
And it directs to their app store (and of course, it is not there)
So, how else, can I specify that it is the default?
When you double click on .mapimail, you should get the option to Look for an app in the store , or More apps.
Choose More apps , scroll down to eM Client and select it. If eM Client is not listed, scroll to the end and choose Look for another app on this PC. Then navigate to C:\Program Files (x86)\eM Client and choose the MailClient.exe file.
