Hi, I’m actually using a pgp keyring for other purposes, can the client connect and use (I mean, if client import/update keys, keyring is kept current too) my keyring, or the client needs have its own ?
Unfortunately eM Client cannot interact with other applications in that way. You will need to import the keys if you want to use them in eM Client.
Ok, understood. Thanks for reply^
