I want to use a signature located somewhere in a folder on the c:/ drive. How can I select this signature in the settings?
I don’t believe there is a way to do that. What I’ve done is copied my signature from a sent e-mail and then gone into the settings and created it. Also, I’ve found the signature on my hard drive and loaded it up and copied and pasted it into the settings in eM Client.
- Merg
Hi, I don’t recomment trying to open this signature, just make a new one in Tools > Settings > Mail > Templates and Signatures.
Using this recommended settings it should be guaranteed that the signature will display correctly in other mail clients when you send out an email.
