I try to access contacts on an Exchange Server 2013 from both eM Client and Outlook 2010. I do not see the files attached with outlook in eM Client nor the files I attached with eM Client with Outlook.
Is there a way to configure eM Client to work with Outlook attachments?
Hello Olaf,
I must admit I am a bit unsure about your issue - what do you mean by these attachments? Did you create contacts in eM Client’s Local folder or in your exchange account’s folder?
eM Client can only access files synchronized to you server, so if the contacts added in Outlook are shown on the server, it should be able to see them. If they are also stored locally, there is no way to access them.
Hello Olaf,
thank you for explaining, I understand the issue now.
Unfortunately, I consulted with out development team and this feature is not finished yet - for some reason Exchange treats the attachments differently to other information stored about the contact.
It’s a feature we are working on though and will fix this in the future updates.
