I want to know what the correct path should be to get to my CardDav server. I tried https:/my_path.com
http:/my_path.com
https:/my_path.com:8443
and many other and nothing worked.
Thanks in advance.
http:/my_path.com
Thanks in advance.
It depends on the server setup. You need to ask your server admin or refer to the guide of your CardDAV software.
I am one of the admins, and the url I have tried is correct, but I don’t think it is the correct format for your system. Any suggestions?
what vendor do you use (for CardDAV server)?
George Wilson
