Hello: I use 9.0.1708 and want to upgrade to 9.2.1735 Are there difficulties with 9.2.1735 …Last I looked a few months ago there were issues after upgrades so I have delayed till now…Thanks Ponder
miércoles 12 abril 2023 :: 2146hrs (UTC +0100)
I have been using v9.2.1735 since it was released about 3 weeks ago on
Win10 Pro & Win11 Pro, with POP3 & IMAP personally I have not had
any issues, however, I can not guarantee that your experience will be
the same though have no reason to believe it will not be the same.
Finally you must make your own decision.
Maybe others might tell you differently.
¡Buena suerte
skybat
¡Los mejores deseos desde Sevilla y mantente a salvo!
Just upraded to 9.2.1735 without a problem…100 % good…Thanks again…Ponder
