I received a notificatiion to update emClient. Did the update and it asked to reboot and now I cant get em client to open. Not good at this busy time to be shut dwon on email. I need assistance asap.
Tried to log in with [email protected] but it did not find that email but that is hte email you have sent all my info and updates to so not sure whats going on there. I had to signup again. Strange.
I had already paid for VIP support in the past,
Please get in touch ASAP! I need help
Dennis Walthers
214.293.5044
[email protected]
I tried do download from emclient site and do a repair and I get another error saying a file does not exiits and cant be installed then closes.
If you are comfortable executing these steps, give this a try:
(1) Delete any installation files you have downloaded.
(2) Uninstall eM Client, making sure to NOT delete your database directory when asked. This will ensure your settings and data remain in place.
(3) If it exists, delete C:\Program Files (x86)\eM Client
(4) Download and install the latest version from Release History 2.
(5) The latest version of eM Client should then start with all your data in place.
Done! It’s performing its checks since it was not closed properly, hopefully this works! Thanks for the quick reply!
