Recently updated and now SMTP and IMAP SSL protocol has been changed and server rejecting.
Only work around is to remove encryption protocol Not good
You can manually change the mail settings to “whatever you had before” so it still works. Go to “Menu / Accounts” and highlight your account and then just change whatever you need to and save settings. Have you tried doing that already.
Do you also have all your mail server details all written down somewhere or if not you can get them from your mailbox support website.
Thanks, tried but I have many email accounts. However the only sure way to get the SMTP to work is select no protocol port 25. Before it was use if available same port Guess I shouldn’t have updated and waited a few months so they could get the bugs out of new update.
