Hi
When updating it, the client to version-v9.2.1735 displays a window in which the need to select the installation file of the old version 9.1222 in the temp folder is displayed. When you select this installer, the following window appears in which it says that the path to the installer is not correct. Attempts to remove or install a more recent version of the program did not give anything. What can I do?
