Unwanted Inbox duplication
I have eMClient handle emails for my two addresses. Sometimes the left pane has an INBOXES entry ‘with’ the two addresses. I have also had instead, an Inbox entry for each address - a much preferred configuration. How can I get and KEEP the latter arrangement ?
It sounds like you’re referring to Inboxes and/or All inboxes.
You can configure which folders and sections you see in Settings > Folders. Try checking/unchecking different options and try them out with the “Apply” button to see what works for you.
https://www.emclient.com/webdocumentation/en/10.0/eMClient/Default.htm#Settings/Folders.htm
