Unread mails
How do I get a list of all unread mails?
it should be displayed under Global Folders->Unread virtual folder. You will need to enable Show Global folders (if it isn’t yet) in menu Tools->Settings->General.
Thanks. I did this and got all unread mails existing in all folders. How do I get unread mails of only Inbox?
Hi.
If you want to see the list of all unread messages in some folder you enter "read:no " to Search and press Enter.
Thanks. A fundamental question. How do I get to search option?
Above the list of your emails there is text field with the string
“Search (type ‘?’ for help)”.
If you enter ‘?’ it displays the list of searching options.
Is this answer to your question?
Thanks. I got it.
