Unknown Senders automation into UNKNOWN folder
I am receiving so much promotional, cold e-mail outreach, etc., that I now need to see from eM Client an easy way to filter all e-mail whose sender is not within my contacts, or past e-mail addresses. Not all of this incoming e-mail is junk, but I receive SO much per day, I cannot focus on my work. Please develop this feature…
Because eM Client relies on your mail server, setting up a strict “contacts only” whitelist would normally need to be done “on your email server” (such as Gmail, Outlook/Exchange, or your hosting provider) rather than inside eM Client.
  • So suggest you Log into your email provider’s webmail or admin portal.
  • Then Create a server-side rule or whitelist that routes incoming mail from addresses not listed in your contacts/safe senders directly to Spam/Junk or deletes them.
  • Once configured on the server, eM Client will only sync the messages that make it past your server’s whitelist.
Your mail server technical support can help you set that up if you carnt see how to do that online.
Also most good mail servers “have spam detection engines” to filter out spam / junk from your Inbox. So suggest to talk to your mail server technical support if that is available for you with your mailbox.
Apart from setting up that on the server end, have a look at this blog for how to manage spam and junk emails with eM Client where you can setup rules & blacklists to block unwanted email addresses or unwanted domains to either go straight to the Junkmail folder or straight to the trash folder.
