I’m uninstalling right away, as the software didn’t give me options to select destination folder during the install process. Hope you can fix this on future versions.
Hi Carlos, eM client is by default installed into the Program Files folder with a default database location in your local Roaming folder.
In case you’d like to install the application in a different folder, you can use this command line:
msiexec /i "pathtolocation\setup.msi" MAILCLIENTINSTALLLOCATION="pathtoinstalllocation"
This is an intended behavior of the application, hope this helps,
Paul
