I moved an appointment and it vanished. Ctrl-Z did not help. Also I’m annoyed about the local calendar, which cannot be removed.
jueves 13 enero 2022 :: 0821hrs (UTC +01:00)
Not clear what you are attempting to do, if you wanted to undo use Ctrl+Y
¡Saludos desde la soleada Sevilla España!
Skybat
[email protected]
Local folders can’t be removed, but they can be hidden from view. Select Menu > Settings > General and untick Show Local Folders.
