Hi…,
is it possible to activate two spelling corrections in eM Client, I need German, and English?
Thanks
Mike
Hi…,
Thanks
Mike
You could load multiple Spell check languages with combined dictionarys that might help you with that via the below methods.
See @Gary post in the following thread
See also @Elegua post in the same thread
There is also currently a Sleekplan suggestion for automatic language detection which you can vote for via the link below if you want that.
I’ll vote. Thanks
If I may interfere with an indirect work-around of sorts, hopefully of some use to others until something similar is implemented in eMC…
I use TextEdit (on a Mac, but I assume there’s something similar on other OS’s) to write practically any mail that’s over a couple of lines long, before pasting it in eMC. One of several reasons for doing this goes back before my moving to eMC, when it seemed that an increasing number of entities avoided to post their contact mail address (or used a no-reply address), leaving only a contact form to get hold of them. If they happen to reply after a week’s time, I want to be able to check on what I wrote in the first place.
Now, on my system there seems (repeat: seems, I cannot remember where it’s located and I haven’t checked in depth) to be a way to select an array of languages that will get spell-checked, as well as whether “errors” will automatically get corrected or not. The result is that, even writing a text in 4 or 5 different languages, only made-up words or words unknown to the spell-checker (typically: trade names) will get wiggly-wigged, allowing to correct them, accept them or even tell the system to remember them.
