With the update I suddenly have two accounts operating from the same name and one other. So I moved all my local folders into one of them but when i go to the accounts menu i cannot tell which one I should delete. i am fearful I will delete all my data! How can I tell which one to delete?
Hello Chris,
the accounts are in the same order in the left menu as in the Menu>Tools>Accounts window.
If your data is in the top account, delete the bottom one and vice versa.
If you want to be extra careful I suggest copying your data into Local folders or exporting them through Menu>File>Export>Export to EML files before deleting.
