New Windows 11 computer and long standing em Client member. How do I transfer the Licence? I have received the Activation Code and it tells me to go to Menu in upper left corner, but there is no Manu icon there.
viernes 16 diciembre 2022 :: 1358hrs (UTC -01:00)
Hey @Martin89
Are you certain that the full eMC is in view?
To check; Right Click and hold the top ribbon and drag to right.
¡Buena suerte!
¡Saludos desde Praia la soleada en Cabo Verde!
skybat
Thank you - now done. But now I can’t see how to move forward and tell my new em Client installation where to find my server company.
viernes 16 diciembre 2022 :: 1755hrs (UTC 00:00)
Hey @Martin89
To move my eMC accounts, settings, data etc to a new computer - The best way to move is through: Backup & Restore.
Follow these steps:
On the old device:
1./ Create a backup: Menu ->Backup
2./ Deactivate the license on this device: Menu ->Help ->License
3./ Find the .ZIP backup file and move it to your new device
The default location is …\Documents\eM Client)
On your new device:
1./ Install eMC (www.emclient.com/dist/latest/setup.msi)
2./Move the ZIP backup file to: …\Documents\eM Client (create the folder if it is not there)
3./ Skip initial setup
4./ Restore from your backup through Menu ->File ->Restore
5./ Activate your license in Menu ->Help ->License
NOTE that not all of the above will apply to you
¡Buena suerte!
¡Saludos mientras navega entre Praia, Cabo Verde y Banjul, Gambia!
skybat
