How can I transfer settings and templates from another computer?
Menu > File > Export > Export settings to .xml file. Then just select those that you want to export.
On the other computer choose Menu > File > Import > eM Client settings (.xml)
I also had templates for quick letters.
That will export the templates as well.
thank you!
