Timezone problems (Calendar)
I’ve created a calendar event at the WebMail Calendar Service but i got the following error message when try to sync with eM Client calendar:
21:58:37 MailExceptions.Exception: Erro na sincronização da pasta CalDAV: System.InvalidOperationException: A operação não é válida devido ao estado atual do objeto.
21:58:37 em System.Linq.Enumerable.Futures1.b\_\_da() 21:58:37 em System.Linq.Enumerable.FirstImpl[TSource](IEnumerable1 source, Func1 empty) 21:58:37 em System.Linq.Enumerable.First[TSource](IEnumerable1 source)
21:58:37 em MailClient.TimeZone.TimeZoneConvert.FromiCalendar(TimeZone timeZone)
21:58:37 em MailClient.Schedule.ScheduleConvert.UpdateScheduleObjectFromComponent(IScheduleObject scheduleObject, Calendar calendar, ScheduleComponent updatingComponent, ScheduleConvertOptions options)
21:58:37 em MailClient.Schedule.Event.EventComposer…ctor(Calendar calendarObject, Event clonedComponent, IEvent parentItem, Boolean removeMethod)
21:58:37 em MailClient.CalDav.Synchronizer.EventItemSynchronizer.CreateItem(Folder folder, Component payloadComponent, Uri uri, String eTag, CancellationToken cancellationToken)
21:58:37 em MailClient.CalDav.Synchronizer.SynchronizeItemsCommand.CreateCalDavItem(Stream payloadStream, Encoding encoding, Uri uri, String eTag)
21:58:37 em MailClient.CalDav.Synchronizer.SynchronizeItemsCommand.CreateCalDavItem(ResponseItem item)
21:58:37 em MailClient.CalDav.Synchronizer.SynchronizeItemsCommand.DownloadItemsMultiget(IList1 uris, Boolean calDav) 21:58:37 em MailClient.CalDav.Synchronizer.SynchronizeItemsCommand.DownloadCalDavItems(IList1 uris)
21:58:37 em MailClient.CalDav.Synchronizer.SynchronizeItemsCommand.ProcessItems(Dictionary`2 items, Boolean deltaSyncReport)
21:58:37 em MailClient.CalDav.Synchronizer.SynchronizeItemsCommand.Execute(WorkerStatus status)
21:58:37 em MailClient.Commands.Command.Process(WorkerStatus status)
Server side timezone is “America/Argentina/Buenos_Aires”, local timezone is America/Buenos_Aires".
Hi Ronison,
may I ask what kind of account is this calenadar connected to?
It’s a CalDAV service provided by an e-mail solution based in Tine 2.0.
Calendar events created using eM Client works fine and syncs normally w/ server.
Apparently , the application does not recognize timezones in the format " America/Sao_Paulo " or " America/Argentina/Buenos_Aires ", but only in Windows format like “E. South America Standard Time” or “Argentina Standard Time” (listed using command “tzutil /l”)…
