Theme buttons not showing completely
Noticing that my Theme buttons don’t show or are misaligned to where they don’t work at times.  I can’t close with the “x” or “apply”.  Tried different themes and the same reaction.
Is this a Theme you edited yourself?
No editing at all.
One thing you can try is to delete your database and see if there is any difference.
Make a backup (Menu > File > Backup) then close eM Client, and delete C:\Users_[username]_\AppData\Roaming\eM Client. You may have to show hidden items in Explorer to do that.
Restart eM Client and see if the buttons are visible.
You might also want to install the latest version of eM Client available at http://www.emclient.com/release-history if you are not already using it.
Thanks got it to work.  It was actually my windowblinds settings.
Yeah, those tweaking apps can cause problems. :slight_smile:
Glad you got it sorted.
