The columns will not remain the way I set them, they revert to the way they were. How can this be fixed.
Hi John,
can you describe the issue more in detail and maybe even take screenshots of how the columns look/are supposed to look? I’m afraid I’m not sure which columns you even mean.
Best regards,
Thanks for your replies to my questions, Olivia. I think this may not be a problem but the way the various views are handled.
If you’re talking about the layout, then that is very strange, as eM Client should save the way you set up your layout by default. What version of eM Client are you running? Can you take screenshots of which part of the layout doesn’t save correctly?
