Tags display
I understand the limited options for tags. But what i don’t understand is why if I tag something in Tasks or Calendar it does not show up in the tags folders in the side folders display in the mail main screen.
Can someone explain this like i’m a 3 yr old cause i just don’t get why you can tag something at it does not go to a folder anywhere. thx
You are in Mail section, so why would you expect to see tagged tasks in mail section? I don’t follow.
i understand why you would ask that, but it’s the only area to view tags (not using gmail)
i guess my question is: if you can tag a task where would it show up to view?
because i don’t see anywhere in tasks to view tags.
does that make sense?
You can use a quick filter to list only the tasks with certain tag.
Thank you Michal!
That definitely works and shows the tags for “Tasks” in filtered tags, page.
I wish all tags were available to view in the main mail sidebar area to make things easier.
But at least you provided a solution.
Thank you.
