I have a html signature which has a combination of images and text in tables. I was hoping to insert this as my signature in emClient but when I do the table itself is visible. It is possible to insert a table in emClient that cannot be seen?
Hi Dave, is the table visible in the signature setup or in the sent email as well, the table may be displayed for editing purposes but when sending the email out it should not be displayed unless your HTML/CSS code says otherwise, e.g. border=1.
Hope this helps,
Hi Paul, thanks for this. Yes I think you’re right. Just wasn’t sure if that would be the case for all recipients. Seems to be working however so thanks for the reply.
Cheers,
- Dave
Hi again, great, glad I could help, let us know if you come across any other questions or issues, we’ll be happy to help.
