System.OutOfMemoryException on startup
Every time EM Client starts up, I get the following error after a few seconds: “System.OutOfMemoryException: Exception of type ‘System.OutOfMemoryException’ was thrown.”  If I ignore the window I can continue using EM Client as normal for a few hours, an then eventually it stops syncing emails.  Whenever it starts up again, it says it wasn’t shut down properly and needs to check the database, which takes some time.
Full details as follows:
eM Client (6.0.22774.0)Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.34014
   at System.IO.BinaryReader.ReadBytes(Int32 count)
   at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.ApplyPatch(Stream patchFile, Stream referenceFile, Stream outputFile)
   at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.GetFolderList(Folder homeFolder, CancellationToken cancellationToken)
   at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass5.b__0(WorkerStatus status, CancellationToken cancellationToken)
at MailClient.Protocols.OfflineAddressBook.OabGenericCommand.Execute(WorkerStatus status)
at MailClient.Commands.SynchronizationQueue.ThreadWorker(Object threadData)
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ThreadHelper.ThreadStart(Object obj)
" rel=“nofollow”>http://emclient.com/ns/report">;
eM Client
6.0.22774.0
false
4.0.30319.34014
mscorlib
mscorlib.dll
100681021
mscorlib
ReadBytes
mscorlib
System.Int32
count
2f
2c
MailClient.exe
100668706
MailClient
ApplyPatch
mscorlib
System.IO.Stream
patchFile
mscorlib
System.IO.Stream
referenceFile
mscorlib
System.IO.Stream
outputFile
a3
175
MailClient.exe
100668708
MailClient
GetFolderList
MailClient
MailClient.Storage.Application.Folder
homeFolder
MailClient
System.Threading.CancellationToken
cancellationToken
4cc
96b
MailClient.exe
100697523
MailClient
MailClient.Protocols.Common.FolderSynchronizer+<>c DisplayClass5
<EnqueueGetFolderList>b
0
MailClient
MailClient.Commands.WorkerStatus
status
MailClient
cancellationToken
1e
6f
MailClient.exe
100668701
MailClient
Execute
MailClient
status
4f
108
MailClient.exe
100664033
MailClient
MailClient.Commands.Command
Process
MailClient
status
15
53
MailClient.exe
100664086
MailClient
ThreadWorker
mscorlib
System.Object
threadData
8c
11a
mscorlib.dll
100669370
mscorlib
ThreadStart_Context
mscorlib
System.Object
state
25
9b
mscorlib.dll
100668987
mscorlib
RunInternal
mscorlib
executionContext
mscorlib
System.Threading.ContextCallback
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
70
a6
mscorlib.dll
100668986
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
0
15
mscorlib.dll
100668985
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
2b
40
mscorlib.dll
100669367
mscorlib
ThreadStart
mscorlib
System.Object
obj
f
4d
MailClient.exe
C:\Program Files (x86)\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
6.0.22774.0
eM Client
eM Client
6.0.22774.0
False
False
False
False
False
Language Neutral
ntdll.dll
C:\Windows\SYSTEM32\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.3.9600.17031 (winblue_gdr.140221-1952)
NT Layer DLL
Microsoft® Windows® Operating System
6.3.9600.17031
False
False
False
False
False
English (United States)
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
6.3.9600.16384 (winblue_rtm.130821-1623)
Microsoft .NET Runtime Execution Engine
6.3.9600.16384
False
False
False
False
False
KERNEL32.dll
C:\Windows\SYSTEM32\KERNEL32.dll
kernel32
kernel32
Windows NT BASE API Client DLL
6.3.9600.17031
False
False
False
False
False
KERNELBASE.dll
C:\Windows\SYSTEM32\KERNELBASE.dll
Kernelbase.dll
Kernelbase.dll.mui
6.3.9600.17031
False
False
False
False
False
ADVAPI32.dll
C:\Windows\SYSTEM32\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
Advanced Windows 32 Base API
6.3.9600.16384
False
False
False
False
False
msvcrt.dll
C:\Windows\SYSTEM32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.9600.17415 (winblue_r4.141028-1500)
Windows NT CRT DLL
7.0.9600.17415
False
False
False
False
False
sechost.dll
C:\Windows\SYSTEM32\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
6.3.9600.16384
False
False
False
False
False
RPCRT4.dll
C:\Windows\SYSTEM32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Remote Procedure Call Runtime
6.3.9600.16384
False
False
False
False
False
SspiCli.dll
C:\Windows\SYSTEM32\SspiCli.dll
security.dll
security.dll
6.3.9600.17415 (winblue_r4.141028-1500)
Security Support Provider Interface
6.3.9600.17415
False
False
False
False
False
CRYPTBASE.dll
C:\Windows\SYSTEM32\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
6.3.9600.17415
False
False
False
False
False
bcryptPrimitives.dll
C:\Windows\SYSTEM32\bcryptPrimitives.dll
bcryptprimitives.dll
Windows Cryptographic Primitives Library
6.3.9600.17415
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.0.30319.34014 built by: FX45W81RTMGDR
Microsoft® .NET Framework
4.0.30319.34014
False
False
False
True
False
SHLWAPI.dll
C:\Windows\SYSTEM32\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell Light-weight Utility Library
6.3.9600.16384
False
False
False
False
False
combase.dll
C:\Windows\SYSTEM32\combase.dll
COMBASE.DLL
COMBASE.DLL.MUI
Microsoft COM for Windows
6.3.9600.16384
False
False
False
False
False
USER32.dll
C:\Windows\SYSTEM32\USER32.dll
user32
user32
Multi-User Windows USER API Client DLL
6.3.9600.16384
False
False
False
False
False
GDI32.dll
C:\Windows\SYSTEM32\GDI32.dll
gdi32
gdi32
6.3.9600.17902 (winblue_ltsb.150609-2200)
GDI Client DLL
6.3.9600.17902
False
False
False
False
False
IMM32.DLL
C:\Windows\system32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
6.3.9600.17415
False
False
False
False
False
MSCTF.dll
C:\Windows\SYSTEM32\MSCTF.dll
MSCTF
MSCTF.DLL.MUI
MSCTF Server DLL
6.3.9600.16384
False
False
False
False
False
clr.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
clr.dll
clr.dll
Microsoft .NET Runtime Common Language Runtime - WorkStation
4.0.30319.34014
False
False
False
True
False
MSVCR120_CLR0400.dll
C:\Windows\SYSTEM32\MSVCR120_CLR0400.dll
msvcr120_clr0400.dll
12.00.51670.34230 built by: FX452RTMGDR
Microsoft® C Runtime Library
Microsoft® Visual Studio® 12 CTP
12.00.51670.34230
False
False
False
False
False
mscorlib.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\c90ef9a73ea0044641d31b19023aad61\mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
Microsoft Common Language Runtime Class Library
4.0.30319.34014
False
False
False
True
False
ole32.dll
C:\Windows\SYSTEM32\ole32.dll
OLE32.DLL
OLE32.DLL.MUI
Microsoft OLE for Windows
6.3.9600.16384
False
False
False
False
False
kernel.appcore.dll
C:\Windows\SYSTEM32\kernel.appcore.dll
kernel.appcore.dll
kernel.appcore.dll
AppModel API Host
6.3.9600.17415
False
False
False
False
False
uxtheme.dll
C:\Windows\system32\uxtheme.dll
UxTheme.dll
UxTheme.dll.mui
Microsoft UxTheme Library
6.3.9600.16384
False
False
False
False
False
saHook.dll
c:\PROGRA~2\mcafee\SITEAD~1\saHook.dll
Email IM Annotation Hook
saHook.dll
4,0,0,356
SiteAdvisor
McAfee WebAdvisor
4,0,0,0
False
False
False
False
False
OLEAUT32.dll
C:\Windows\SYSTEM32\OLEAUT32.dll
OLEAUT32.DLL
6.3.9600.17560
6.3.9600.17560
False
False
False
False
False
System.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System\1c5fe4cb68f67046baec4c3a854f722f\System.ni.dll
System.dll
System.dll
4.0.30319.34239 built by: FX452RTMGDR
.NET Framework
4.0.30319.34239
False
False
False
True
False
CRYPTSP.dll
C:\Windows\SYSTEM32\CRYPTSP.dll
cryptsp.dll
cryptsp.dll
Cryptographic Service Provider API
6.3.9600.17415
False
False
False
False
False
rsaenh.dll
C:\Windows\system32\rsaenh.dll
rsaenh.dll
rsaenh.dll.mui
Microsoft Enhanced Cryptographic Provider
6.3.9600.16384
False
False
False
False
False
bcrypt.dll
C:\Windows\SYSTEM32\bcrypt.dll
bcrypt.dll
bcrypt.dll.mui
6.3.9600.16384
False
False
False
False
False
MailClient.Collections.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.1d52ed9e#\f6dccfa9f56a2ac902ed7ea9489b2000\MailClient.Collections.ni.dll
MailClient.Collections.dll
6.0.22774.0
6.0.22774.0
False
False
False
False
False
Language Neutral
MailClient.Mail.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Mail\95bdd98e1a8c3a96cda0f650a84da197\MailClient.Mail.ni.dll
MailClient.Mail.dll
MailClient.Mail.dll
6.0.22774.0
6.0.22774.0
False
False
False
False
False
Language Neutral
HTMLEditorControl.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\HTMLEditorControl\e2b5a48f5e308d229ae1494c6c2a0006\HTMLEditorControl.ni.dll
HTMLEditorControl.dll
6.0.22774.0
HtmlEditorControl
6.0.22774.0
False
False
False
False
False
Language Neutral
MailClient.ni.exe
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient\5e2ef91993e6753fc3a20c833b37859b\MailClient.ni.exe
MailClient.exe
MailClient.exe
6.0.22774.0
eM Client
Hello, sorry to see this, can you please try to update your eM Client to this release, 6.0.22930.0 and check if the issue persists?
This seems to have worked.  I will continue to monitor and see how it goes.  Thanks Paul!
Glad it works, please make sure to let us know if the issue reoccurs or if you come across any other issues or questions about the application, we’ll be happy to help.
Hi Paul,
I’m not seeing the previous error, but I’m still getting an Operations Error: “Set action is invalid for property.”  This can be ignored easily, but it would be good to find out why it is happening.
Startup log is as follows:
08:24:20 Online state: changed to online due to NetworkAvailability 08:24:22 Swire [Exchange Web Services]  Synchronizing folder list
08:24:44 Swire [Exchange Web Services]  Uploading item(s) to folder ‘Swire/Inbox/~ For Deletion ~/’
08:25:00 Swire [Offline Address Book]  Synchronizing folder list
08:25:00 Swire [Exchange Web Services]  Moving item(s) from folder ‘Swire/Trash/’ to folder ‘Swire/Inbox/~ For Deletion ~/’
08:25:00 Swire [Exchange Web Services]  Uploading item(s) to folder ‘Swire/Calendar/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder list
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/Inter-Company Address/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/All Rooms/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/Purchasing (Email)/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/Altus Logistics/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/Global Address List/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/Internet Address/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/All Users/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/Vessels PRIORITY Messages/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/All Groups/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/All Contacts/’
08:25:01 Swire [Offline Address Book]  Synchronizing folder ‘Swire/Vessels ROUTINE Messages/’
08:25:01   MailExceptions.OperationException: Set action is invalid for property.
08:25:01 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/
08:25:01 Gmail [GData]  Synchronizing folder list
08:25:01 Swire [Exchange Web Services]  Synchronizing folder list
08:25:01 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Inbox/’
08:25:02 Gmail [GData]  Synchronizing folder list
08:25:03 Gmail [GData]  Synchronizing folder list
08:25:04 Gmail [GData]  Synchronizing folder ‘Gmail/Contacts/’
08:25:04 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:04 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/Inbox
08:25:05 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:05 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/[Gmail]
08:25:05 Gmail [GData]  Synchronizing folder ‘Gmail/[email protected]/’
08:25:06 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:06 Gmail [IMAP]  Synchronizing messages: For folder Gmail/Inbox
08:25:06 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Calendar/’
08:25:06 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Contacts/’
08:25:06 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Drafts/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Tasks/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Sync Issues/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Inbox/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Outbox/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Sent/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Trash/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Junk E-mail/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Suggested Contacts/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Sync Issues/Conflicts/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Sync Issues/Local Failures/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Sync Issues/Server Failures/’
08:25:07 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Inbox/Daily SitReps/’
08:25:07 Gmail [IMAP]  Synchronizing messages: Done
08:25:07 Gmail [IMAP]  Synchronizing messages: For folder Gmail/[Gmail]/All Mail
08:25:11 Gmail [IMAP]  Synchronizing messages: Done
08:25:11 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/[Gmail]/All Mail
08:25:12 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:12 Gmail [IMAP]  Synchronizing messages: For folder Gmail/[Gmail]/Bin
08:25:14 Gmail [IMAP]  Synchronizing messages: Done
08:25:14 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/[Gmail]/Bin
08:25:14 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:14 Gmail [IMAP]  Synchronizing messages: For folder Gmail/[Gmail]/Drafts
08:25:14 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/[Gmail]/Drafts
08:25:15 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:15 Gmail [IMAP]  Synchronizing messages: For folder Gmail/[Gmail]/Important
08:25:16 Gmail [IMAP]  Synchronizing messages: Done
08:25:16 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/[Gmail]/Important
08:25:16 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Inbox/Personal/’
08:25:16 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Inbox/~ Archive ~/’
08:25:16 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:16 Gmail [IMAP]  Synchronizing messages: For folder Gmail/[Gmail]/Sent Mail
08:25:18 Gmail [IMAP]  Synchronizing messages: Done
08:25:18 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/[Gmail]/Sent Mail
08:25:18 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:18 Gmail [IMAP]  Synchronizing messages: For folder Gmail/[Gmail]/Spam
08:25:18 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Inbox/Pre-Departure Orientation/’
08:25:18 Swire [Exchange Web Services]  Synchronizing folder ‘Swire/Inbox/~ For Deletion ~/’
08:25:19 Gmail [IMAP]  Synchronizing messages: Done
08:25:19 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/[Gmail]/Spam
08:25:19 Gmail [IMAP]  Synchronizing subfolders: Done
08:25:19 Gmail [IMAP]  Synchronizing messages: For folder Gmail/[Gmail]/Starred
08:25:19 Gmail [IMAP]  Synchronizing subfolders: For folder Gmail/[Gmail]/Starred
08:25:20 Gmail [IMAP]  Synchronizing subfolders: Done
Hello again Richard, glad the crash is no longer occurring, can you please create some additional logging data for us to share more information about the error, please navigate to Tools > Settings > Advanced and enable Exchange Web Services logging for the problematic Exchange account?
Save the settings and replicate the issue, once the error reoccurs, please restart eM Client and navigate back to the advanced settings window, use the “Send logs” button and submit the logging data to my work mail, [email protected] with a reference link to this forum topic for more information about this specific error.
Hi Paul,
It’s been 4 days now and this error has not re-occurred, so hopefully this is closed now.
Thanks once again for your help.
Glad it works, please make sure to let us know if you come across any other issues or questions about the application, we’ll be happy to help.
I  had the same issue and discovered the Offline Address Book (OAB) syncing service was the culprit.  I suspect it’s because in a corporate environment the Global Directory is too large for the client to handle or they have security restrictions specific to address books…
If you encounter this issue, try disabling the OAB web service under account settings
