System.net.log.trace from em client is huge!
I noticed that I had a file that would grow to enormous sizes such as 100gb+ and its a persistent problem with em client.  The file is named “system.net.log.trace” and today it was 48gb in size. Went to delete the file and it said em client was writing to it. Can you guys remedy this?
I did some research and came up with, The System.Net source emits logging messages from the HttpWebRequest and HttpWebResponse classes.
Do you have logging enabled at Settings–>Advanced–>Logging?
Uncheck all the boxes and clear the log. You should only use this feature when directed by the eMC folks.
What is the directory location of this huge file you mentioned?
