After installing eM Client on a new PC running Windows 11, I noticed that the system folders (such as “Inbox” or “Sent”) are displayed in English instead of German (‘Posteingang’ or “Gesendet”). When installed on my previous computer (Windows 10), the system folders are displayed correctly in German. The same is true on my smartphone (Android).
The program language is set correctly, and resynchronizing the folders does not resolve the issue.
How can I fix this problem?
I was able to fix the problem myself:
It’s apparently related to the message “Smart App Control has blocked part of this app.”
A DLL file from eM Client was flagged by Windows 11 as untrusted or insufficiently signed, and this also affected the translation of the system folders.
The simplest solution was to uninstall eM Client (while keeping the database) and install the version from the Microsoft Store.
Now everything works as expected ![]()
Yes Smart app control can block alot of programs. i have mine turned off in Windows 11. Windows Defender / Security will continue to function. Or you can disable it and then re-enable after the eM Client installation if your worried and want to use Smart App Control.
To disable Smart App Control, open Windows Settings > Privacy & Security > Windows Security > Apps & Browser control > Smart App Control > Off.
The simplest solution was to uninstall eM Client (while keeping the database) and install the version from the Microsoft Store. Now everything works as expected
The only downside of running the Windows Store version is that its not always as up to date as the website version. So id personally recommend just to disable Smart App Control.
