EM Client crashes and will not function anymore. Reinstalled the application but it keeps crashing.
Hereunder is the first part of the failurenotice. What can I do to fix this?
eM Client (7.0.27943.0)Windows: Microsoft Windows NT 10.0.10586.0, Framework: 4.0.30319.42000
System.Data.SQLite.SQLiteException (0x80004005): constraint failed
UNIQUE constraint failed: MailCategoryNames.categoryName, MailCategoryNames.id
bij System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
bij System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
bij System.Data.SQLite.SQLiteDataReader.NextResult()
bij System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
bij System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
bij System.Data.SQLite.SQLiteCommand.ExecuteScalar()
bij MailClient.Storage.Data.DbItemRepository1.StoreCategoryName(UInt64 parentId, String categoryName) bij MailClient.Storage.Mail.Data.DbMailRepository.\<\>c\_\_DisplayClass95\_0.<store>b__0(String i)<br> bij MailClient.Storage.Data.CategoryNameCollection.From(IEnumerable
1 values, Func2 storeValue)<br> bij MailClient.Storage.Mail.Data.DbMailRepository.Store(IMailRepositoryItem mail)<br> bij MailClient.Storage.Data.DbRepository
1.Add[ST](Object senderContext, IEnumerable1 items)<br> bij MailClient.RepositoryExtensions.Add[T,ST](IRepository
1 repository, IEnumerable`1 items)
bij MailClient.Protocols.Imap.Synchronizer.SynchronizeMessagesCommand.Fetch(FetchNotification response)
bij MailClient.Protocols.Imap.Synchronizer.Fetch(Folder folder, FetchNotification response)
bij MailClient.Protocols.Imap.Synchronizer.ImapNotification(ConnectionPoolEntry connectionPoolEntry, Folder activeFolder, NotificationEventArgs e)
bij MailClient.Protocols.Imap.ConnectionPoolEntry.Connection_Notification(Object sender, NotificationEventArgs e)
bij MailClient.Imap.Base.Connection.ParseUntagged(String line)
bij MailClient.Imap.Base.Connection.ParseReply(String line)
bij MailClient.Imap.Base.Connection.ReceiveWorker()
bij System.Threading.ThreadHelper.ThreadStart_Context(Object state)
bij System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
bij System.Threading.ThreadHelper.ThreadStart()
" rel=“nofollow” target="_blank">http://emclient.com/ns/report">;
