How can I keep synchronized several signatures between 2 computers without being forced to use the backup/restore option?
Thanks in advance.
Best regards
Thanks in advance.
Best regards
There is no option to do that automatically unless you are using IceWarp servers.
You can do it manually by Menu > File > Export > Export settings as .xml file. Then you can choose just the Signatures option.
Another option is with eM Client closed copy C:\Users[username]\AppData\Roaming\eM Client\snippets.dat to another computer. You may have to enable hidden items in Explorer to do that.
Thanks Gary for your help!
