.Email synchronization with IONOS has stopped working as of today.
Email synchronisation with IONOS has stopped working as of today.
If suddenly all your accounts stop working and you haven’t changed anything in your email settings and you can login ok to your webmail for these accounts online, then could be something outside the Mail client causing it like an eg: optionally installed firewall / security program or optionally installed antivirus program or vpn or it could be a server related issue.
So first if you have anything like the above optional programs installed “other than what comes default with your OS, try completing disabling those to test incase of interferance.
If you have nothing like that optionally installed or you do but disabling made no difference, then next “check with your mail server technical support” to see if they are aware of any mail client connection issues today as could be a problem their end with mail clients connecting globally.
If your technical support say they have no issues their end, then check your ionos mail settings.
Depending on your eM Client version i believe these are the Ionos account server settings.
eM Client V10.3.x or higher
(IMAP)
imap.ionos.com Port 993 "Use TLS on Special Port”
Or
imap.ionos.com Port 143 "Use STARTTLS if available”
(SMTP)
smtp.ionos.com Port 465 "Use TLS on Special Port”
Or
smtp.ionos.com Port 587 "Use STARTTLS (Always)”
eM Client V6 to V10.2
(IMAP)
imap.ionos.com Port 993 Use SSL/TLS on special port (legacy)
Or
imap.ionos.com Port 143 Use SSL/TLS if available
(SMTP)
smtp.ionos.com Port 465 = Use SSL/TLS on special port (legacy)
Or
smtp.ionos.com Port 587 Force usage of SSL/TLS
If none of the above helps you, then if you have only just joined eM Client and are still inside your 30day trial period, then suggest to email [email protected] for initial trial assistance.
If you are outside your 30day trial and you have a current active paid Pro, Personal or Business version go to the following VIP support page and login and lodge a support ticket.
After contacting support, a new pre-release version (10.4.5674) helped me.
