Synchronization sometimes gets stuck saying “Synchronization Messages”. Nothing happens, no new entries in the log. I tried to restart the eM Client. It did not help. After some time the synchronize process gets running, performing all the steps. I tried to find out why this process waked up, but I did not. In the same way, without any reason which I can see, the synchronizing process gets stuck again.
Hi Ivo, what version of eM Client are you currently using on your computer, can you check for the exact version number in Help > About?
What mail service are you using with eM Client? Are you using an IMAP account?
Are you using any firewall/proxy software on your computer?
When the application “gets stuck”, is it responding to your actions or is the application frozen on the synchronization.
Hi Paul.
thank you for your very fast answer.
My eM Client version: 6.0.21040.0
My mail operator is swedish “Telia.com”
I am using the standard Windows firewall
I am not using Proxy.
I have IMAP account. Even, when eM Client is hanging on “Synchronizing messages”, I can send and read messages on my iPad. Because of that I don’t believe, that the problem is on the server’s side. When I send a message from eM Client to myself, I can read it immediate on my iPad, but the eM Client deliveres this message much later. In the log I can see, that eM Client did one or two successfull reading attempts after some minute, delivered my message to myself and then got stuck again. Sometimes it wakes up and runs normally.
eM Client is frozen just in the window “Operations”. Otherwise I can use any other function in the application. I can “Hide” the Operations window, I can “Send and Receive” manually, but the Operations windows appears again with “Synchronizing Messages”.
Thank you. Regards
Ivo
I want to complete my previous issue description with some new observations of unnormal behaviour of the application. I received a message which was shown only as a heading competed with the following: “The message will be downloaded the next time you are online.”
My computer was online!! I tried to get the message via activating “Send and Receive”. It did not help. I had to go to “File” and activate “Work Offline”, “File” again and deactivate “Work Offline”. First after that I received the message. I also received an error message as follows: ![]( “Image null”)
![]( “Image 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”)
Hi again Ivo, I can’t unfortunately display the attached screenshot, can you please make sure you’ve attached the image to your reply. When the error occurs, can you please switch to the “Log” tab, copy the content of the log and post it here on the forum?
Hi, I remember that I had some problems with attaching a picture to my message. I will try again. Only the first part of the message is interesting in this case. The second part appears from time to time. I ignore it, I guess that my server just might have been occupied, too short waiting time or something like that. This is no problem, only the first part is mysterious. I WAS ONLINE !
I hope you will get the screenshot this time. I can see it here, it should be inserted .
Regards
Ivo
Hi again Ivo, thank you for the screenshot, can you please switch to the “Log” tab as I suggested, copy the content of the log and post it here on the forum?
Hi Paul,
I am sorry, I can’t send you the “log” you want to see. Yesterday I had to send my Win 8.1 computer on service. I temporarily use eM Client on my very old Win XP computer which I had to wake up. I will return to our discussion and testing as soon as I get my Win 8.1 computer back. Probably within two weeks.
Thank you.
Ivo
Hi Paul,
I am returning to this problem after getting back my computer from the service.
The situation with “Synchronization stuck” seems to be exactly the same as before the service.
Here follows the information you wanted from me with some comments:
I knew, (by phone) that there was a mail sent to me at 17:54
I cleared the log in the “Operations” windows and started “Send and receive” function.
Result in the Operations log is as follows:
18:06:07 Online state: changed to online with reason NetworkAvailability
18:06:07 [email protected] [IMAP] Synchronizing message flags: For folder [email protected]/Trash
18:06:07 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
18:06:07 [email protected] [IMAP] Synchronizing subfolders: Done
18:06:07 [email protected] [IMAP] Synchronizing messages: For folder [email protected]/Inbox
18:06:07 [email protected] [IMAP] Synchronizing message flags: Done
In this situation the Synchronization Operations function was hanging with “Synchronizing messages”.
The current log available in the “Operations” windows is shown above.
I experienced, that there was a chance to wake up the “Operations” by sending a mail to myself. I did it and I received both the expected mail from 17:54 and the mail I sent to myself.
Here is result in the log:
18:15:08 [email protected] [IMAP] Synchronizing messages: For folder [email protected]/Inbox
18:16:07 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
18:16:07 [email protected] [IMAP] Synchronizing subfolders: Done
18:16:07 [email protected] [IMAP] Synchronizing messages: For folder [email protected]/Inbox
18:25:08 [email protected] [IMAP] Synchronizing messages: For folder [email protected]/Inbox
18:25:08 [email protected] [IMAP] Synchronizing messages: Done
18:25:08 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
18:25:08 [email protected] [IMAP] Synchronizing subfolders: Done
18:26:07 [email protected] [SMTP] Connecting: To [email protected]
18:26:07 [email protected] [SMTP] Connected: To [email protected]
18:26:07 [email protected] [SMTP] Sending messages
18:26:07 [email protected] [SMTP] Disconnected: From [email protected]
18:26:07 [email protected] [SMTP] Disconnected: Done
18:26:07 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
18:26:07 [email protected] [IMAP] Uploading messages: To folder [email protected]/Sent
18:26:08 [email protected] [IMAP] Uploading messages: Done
18:26:08 [email protected] [IMAP] Synchronizing subfolders: Done
18:26:08 [email protected] [IMAP] Synchronizing messages: For folder [email protected]/Inbox
18:26:08 [email protected] [IMAP] Synchronizing messages: Done
18:26:12 [email protected] [IMAP] Downloading message part…
18:26:12 [email protected] [IMAP] Downloading message part…: Done
18:26:14 [email protected] [IMAP] Synchronizing messages: For folder[email protected]/Sent
18:26:14 [email protected] [IMAP] Synchronizing messages: Done
18:26:22 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
18:26:22 [email protected] [IMAP] Synchronizing subfolders: Done
18:26:28 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
18:26:28 [email protected] [IMAP] Synchronizing subfolders: Done
18:26:35 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
18:26:35 [email protected] [IMAP] Synchronizing subfolders: Done
18:26:43 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
18:26:44 [email protected] [IMAP] Synchronizing subfolders: Done
It seems, that the “Operations” function is working again until … ?? I do not know what is the reason that the “Operations” function gets hanging again after some time.
Here follows the contents of the sqlite.log created after I received my computer from the service:
12/30/2014 08:33:37 1 no such table: mail_fti.SubjectIndex_stat
12/30/2014 08:33:37 1 no such table: mail_fti.AddressIndex_stat
12/30/2014 08:34:36 1 no such table: mail_fti.LocalMailsIndex3_stat
12/30/2014 08:50:15 1 no such table: mail_fti.SubjectIndex_stat
12/30/2014 08:50:15 1 no such table: mail_fti.AddressIndex_stat
12/30/2014 08:50:15 1 no such table: mail_fti.LocalMailsIndex3_stat
12/30/2014 17:53:35 1 no such table: mail_fti.AddressIndex_stat
12/30/2014 17:53:35 1 no such table: mail_fti.SubjectIndex_stat
12/30/2014 17:53:35 1 no such table: mail_fti.LocalMailsIndex3_stat
12/30/2014 18:07:45 1 no such table: mail_fti.SubjectIndex_stat
12/30/2014 18:07:45 1 no such table: mail_fti.AddressIndex_stat
12/30/2014 18:08:00 1 no such table: mail_fti.LocalMailsIndex3_stat
12/30/2014 18:13:59 1 no such table: mail_fti.AddressIndex_stat
12/30/2014 18:13:59 1 no such table: mail_fti.SubjectIndex_stat
12/30/2014 18:14:00 1 no such table: mail_fti.LocalMailsIndex3_stat
12/31/2014 10:16:24 1 no such table: mail_fti.LocalMailsIndex3_stat
12/31/2014 10:16:49 1 no such table: mail_fti.SubjectIndex_stat
12/31/2014 10:16:49 1 no such table: mail_fti.AddressIndex_stat
12/31/2014 17:06:07 1 no such table: mail_fti.AddressIndex_stat
12/31/2014 17:06:07 1 no such table: mail_fti.SubjectIndex_stat
12/31/2014 17:06:07 1 no such table: mail_fti.LocalMailsIndex3_stat
It seems, that time in the “Operations” log is my local time, while time in the sqlite.log is GMT time.
I hope, that my report will help you to analyze this issue.
Best regards
Ivo
Hi again Ivo, can you please try to update your eM Client to this release and check if the issue persists, http://www.emclient.com/dist/v6.0.21364/setup.msi?
If it does, can you please navigate to Tools > Settings > Advanced and enable IMAP logging for the problematic account
- Save the settings
- Restart the application
- Replicate the issue
When the issue reoccurs, please go back to the advanced settings window and click on “Send logs” and submit the logs to my email [email protected] with a reference link to this forum topic.
Paul
Hi Paul, here I am again back with the Synchronization stuck issue. First of all, I want to say, that I like eM Client, the logic, the functions and more, but it is not reliable. Sometimes it is working perfect for hours, even for some days, but then it fastens in a loop which is almost unpossible to release. I can see new incoming mails on my iPad, but nothing can I see on my PC. These mails appear on my PC, hours or days later, when the Operations loop is released. Sometimes it is released automaticaly, sometimes it helps if I change the IMAP port numer to anything else and then back to the correct value. This helps sometimes, not always. Sometimes it helps to run the account diagnostic and generate the Test message, sometimes it does not. Once, I received the automaticaly generated diagnostic Test message, which contained text from another message !!!
Normally I do not shut down my computer on the evenings, I only hibernate. Very often it happens, that mails, which arrived to the operator’s webmail during the time period when my PC was hibernated, are not presented in the eM Clients inbox. I can see them on my iPad, I can see them on my operator’s webmail, but they are never shown in eM Client. They just disappear.
Please tell me, is there anything I can do? I am prepared to cooperate with you in order to solve this problem, but I am sorry to say, that I am considering to leave eM Client if this issue would persist. I am really very sorry.
Please, tell me, if there is anything I can do to help you to solve this problem to be able to continue with eM Client?
Best regards
Ivo Bartonek
I am having the same problem.
Paul S
Hi Ivo, what version of eM Client are you currently using on your computer, can you please check for the exact version number in Help > About?
What mail service are you using with eM Client? If you’re seeing any errors while trying to synchronize the items with your server, can you please make a screenshot of the error that’s being thrown by the application and submit it to us here on the forum?
Paul
Hi Paul,
I have the latest version 6.0.21372.0
My mail service is “webmail.telia.com”
Just now my eM Client is running without problems. As soon as I receive any error message, you will receive the screenshot.
If you want, I can take a dump as soon as I would see the little circle rotating beside the account name too long, i.e. when synchronizing gets in loop.
Just now I am also trying to avoid a possible conflict with hibernation. I close eM Client before I hibernate Windows. We’ll see if it helps
Regards Ivo
Hi Ver 6.0.21372.0
It seems that it has nothing to do with hibernation. I closed eM Client before every hibernation, but the hanging Operations message “Synchronizing messages” is here again. Cannot receive messages, cannot send messages until this loop would be released. I could not find any special reason or circumstance why the loop appears or why and when it is released.
Ivo
This error message appears from time to time, but it seems that it has nothing to do with the hanging “Synchronizing messages”. I assume, that the problem is the “…temporary server unavailability”
I have the same issue. eM Client is just too unreliable, it too often gets stuck in its attempt to retrieve emails, with the wait loop turning next to the mail account name. At which point no mail comes in anymore, for minutes or hours or days. I usually have to kill and restart it, and usually it would come back alive for a while, but today it got stuck again right away without pulling any emails at all (my other clients see the emails just fine). It’s been annoying and now essentially getting to be useless. Even simple things like deleting an email randomly gives a “This may take a while” popup that takes several seconds to go away, and occasionally the whole app just freezes for no reason, either way I end up typing or clicking ahead with no response and it’s not a productive experience. I’ve never seen any other email client do this, with my same providers. It’s clearly an eM Client issue.
Please, come on guys, this problem has been there for over a year, you don’t need to wait for logs to figure it out (and I *have* given logs in the past and nothing ever came of it) – just get someone competent to review the mail retrieval code.
I’m having same problem too… but I’m not using IMAP, instead I’m connected to exchange trough the webservice…
Same sqlite log entries with …
04/23/2015 05:52:19 1 no such table: mail_fti.SubjectIndex_stat04/23/2015 05:52:19 1 no such table: mail_fti.AddressIndex_stat
04/23/2015 05:52:19 1 no such table: mail_fti.LocalMailsIndex3_stat
04/23/2015 06:28:28 1 no such table: mail_fti.SubjectIndex_stat
04/23/2015 06:28:28 1 no such table: mail_fti.AddressIndex_stat
04/23/2015 06:28:28 1 no such table: mail_fti.LocalMailsIndex3_stat
04/23/2015 07:27:03 1 no such table: mail_fti.SubjectIndex_stat
04/23/2015 07:27:03 1 no such table: mail_fti.AddressIndex_stat
04/23/2015 07:27:03 1 no such table: mail_fti.LocalMailsIndex3_stat
04/23/2015 07:30:47 1 no such table: mail_fti.SubjectIndex_stat
04/23/2015 07:30:47 1 no such table: mail_fti.AddressIndex_stat
04/23/2015 07:30:47 1 no such table: mail_fti.LocalMailsIndex3_stat
I’m using the latest version, and our server is running fine, as I can see my emails updated normally from webmail, and from outlook.
Any logs that I can send for analysis?
Please make sure you’re running the latest release of eM Client (6.0.22336.0) and let us know if the issue persists. I’m afraid that without proper logging data we’re unable to replicate the issue, and thus resolve it.
I’m sorry that you’re experiencing this issue, but unfortunately we’re currently not able to replicate this problem. If you’re having issues with this, you can submit new logging data to us or create a dump file using this tool, http://www.emclient.com/tools/emstackdump.exe when the application is frozen or doesn’t respond to user requests.
However note that these hangs can also be caused by server not responding to application’s requests.
