Hi, what exactly are you having issues with? If you’re using IMAP for email synchronization, your calendars, tasks etc. should be synchronized with the server automatically with eM client and your phone.
I work off a pop 3 system and can’t get the calendar to sync,with my xperia phone. Imap doesn’t delete the emails on our server once downloaded so have to use pop 3… Thanks for the help
Using POP3 it’s not possible to synchronize the calendar, POP3 protocol is used for only receiving new email and doesn’t give a response back to the server, calendar, contacts and other services are not supported for POP3 account, you’d have to use IMAP for synchronization between multiple devices.
Thank you for understanding,
