I am considering to buying the em client
but something bothers me a lot.
the sync not run in background but a window opens constantly. annoying when you set the sync interval to 1 minute and also work with the pc
Does this help resolve your issue?
Menu > Settings > General > Operations Window
no , I can only set there whether it should be synchronized and how often this should not to do this in the background
Hmm, I don’t have “window opens constantly” occurring, based on the setting I pointed you to.
Perhaps you can grab a screen shot of the window so we can ensure we are talking about the same thing?
I using em client in german.
and used since thunderbird and there it was normal that everything runs in the background
Thanks for the screen shot… I now understand and can not ever remember seeing anything like that in the versions I have run.
I too ran Thunderbird…
Hopefully someone more knowledgeable than I will be able to respond to your issue…
@niwes: Menü > Einstellungen > Allgemein > Allgemein > Einstellungen > “Statusfenster beim Senden und Empfangen anzeigen” deaktivieren.
@sunriseal: The German translation of the settings is not quite consistent with the English version. I suppose that’s why niwes did not find your path.
Oh… guess I did not fully understand that he could not find it…
So the settings as I pointed him to, should help him?
Yes, you pointed him to the right settings. The German language version of the settings is a bit confusing, that’s why he did not find it.
Thank you… !!
I realize he is German but since the original post was in English it never crossed my mind that language would be a problem…
@ezrider thaks thats it
I also put it in English but hadn’t found anything suitable
@sunriseal thank you too
now i thinking i buy one
Glad it all worked out! Enjoy!
