Stuck with an error message
I tried to sync the United states calendar but it would not work. I am stuck with a message that says “You chose to resolve the upload problem byndeleting the uploaded item. Are you sure you want to delete this item?” It keeps popping up after I say yes. Do you know how to fix this?
You were probably trying to upload the events to the write protected calendar and now it is causing troubles when you want to delete them. Please enable GData logging and try to simulate the issue. Then send us the logs using the same logging settings window. Thank you.
