Hello
Been a EMC user for a couple of years and have just done a fresh install of Win10 and found the EMC Version 7 so installed that.
Changed storage location, moved files across re-opened EMC. Seems to be working as my account settings have been copied across but in settings it still shows the original location.
When I open the new location in Explorer with EMC running I have shm & wal files which disappear when EMC is closed. This makes me think it’s all working OK, just the location showing incorrectly in settings.
Also has the xml file that had to remain in the older versions gone? Does this mean I can delete the original storage location folder?
Cheers
