The program keeps stopping when I am about to send mail and when I fill in the report to send it disappears and when I download the latest update it stops at windows configuration - it could be my computer - and one message won’t downloard - parse comment - whatever that means - but I like your program none the less. Thanks.
You are giving way to little information for the developers to do something with this. You aren’t giving any relative, technical information about your issue. So it’s impossible to help you with this.
Is there any error-code given? What system are you using (specs.)? What programm’s are running? Sounds to me that this is a Windows-issue.
